json input:
"id": 383853,
"temp": 24.2,
"ph": 2.89,
"conductivity": 16.57,
"speed": 540,
"substrate_id": "B02312023091301280",
"date_time": 1700207501
telegraf config:
[[inputs.mqtt_consumer]]
servers = ["tcp://192.168.0.129:1883"]
topics = [
"mqtt/csv_test",
qos = 2
client_id = "XX"
username = "XX"
password = "XX"
data_format = "json_v2"
measurement_name = "csv_file_test"
timestamp_path = "date_time"
timestamp_format = "unix"
timestamp_timezone = "Asia/Shanghai"
path = "id"
path = "temp"
path = "ph"
path = "conductivity"
path = "speed"
path = "substrate_id"
type = "string"
[[processors.printer]]
Logs from Telegraf
2023-11-23T03:01:44Z D! [outputs.influxdb_v2] Buffer fullness: 0 / 10000 metrics
2023-11-23T03:01:54Z D! [outputs.influxdb_v2] Buffer fullness: 0 / 10000 metrics
csv_file_test,host=895ee07f3228,topic=mqtt/csv_test id=383844,temp=24.1,ph=2.91,conductivity=16.57,speed=540,substrate_id="A02312023111002040" 1700206986000000000
csv_file_test,host=895ee07f3228,topic=mqtt/csv_test id=383845,temp=24.1,ph=2.91,conductivity=16.57,speed=540,substrate_id="A02312023111008070" 1700207038000000000
csv_file_test,host=895ee07f3228,topic=mqtt/csv_test id=383846,temp=24.1,ph=2.91,conductivity=16.57,speed=540,substrate_id="A02312023111008060" 1700207102000000000
csv_file_test,host=895ee07f3228,topic=mqtt/csv_test id=383847,temp=24.1,ph=2.91,conductivity=16.57,speed=540,substrate_id="A02312023111003330" 1700207154000000000
csv_file_test,host=895ee07f3228,topic=mqtt/csv_test id=383848,temp=24.1,ph=2.91,conductivity=16.57,speed=540,substrate_id="A02312023111003380" 1700207218000000000
csv_file_test,host=895ee07f3228,topic=mqtt/csv_test id=383849,temp=24.1,ph=2.91,conductivity=16.57,speed=540,substrate_id="A02312023111007040" 1700207270000000000
csv_file_test,host=895ee07f3228,topic=mqtt/csv_test id=383850,temp=24.1,ph=2.9,conductivity=16.57,speed=540,substrate_id="NULL" 1700207333000000000
csv_file_test,host=895ee07f3228,topic=mqtt/csv_test id=383851,temp=24.2,ph=2.9,conductivity=16.57,speed=540,substrate_id="A02312023111003050" 1700207385000000000
csv_file_test,host=895ee07f3228,topic=mqtt/csv_test id=383852,temp=24.1,ph=2.89,conductivity=16.57,speed=540,substrate_id="A02312023111003060" 1700207449000000000
csv_file_test,host=895ee07f3228,topic=mqtt/csv_test id=383853,temp=24.2,ph=2.89,conductivity=16.57,speed=540,substrate_id="B02312023091301280" 1700207501000000000
2023-11-23T03:02:04Z D! [outputs.influxdb_v2] Wrote batch of 10 metrics in 4.218801ms
2023-11-23T03:02:04Z D! [outputs.influxdb_v2] Buffer fullness: 0 / 10000 metrics
2023-11-23T03:02:14Z D! [outputs.influxdb_v2] Buffer fullness: 0 / 10000 metrics
Expected behavior
This data will post in influxdb
Actual behavior
The bucket not receive any data
Steps to reproduce
- if i don’t config the
timestamp_path = "data_time"
, all data will post in influxdb - i try use
data_format = json
, configjson_time_key = "data_time"
, the data also don’t post to influxdb
System info
Ubuntu 22.04, Influxdb 2.7.4(Docker), Telegraf(Alpine Docker)
PS: also in github:mqtt json can't post to influxdb · Issue #14336 · influxdata/telegraf · GitHub
