Hi everyone! I´ve been trying to use an Arduino UNO to publish a json to a mqtt broker, the use telegraf to collect said json and send it to an influx database. I installed telegraf and influxdb 1.8 and then started the telegraf service using Windows´ PowerShell ISE, and it says it has connected with the MQTT broker correctly.
2020-04-25T16:31:01Z I! [inputs.mqtt_consumer] Connected [tcp://52.29.186.242:1883]
When I open the influxd.exe, I get the following message whenever the json is published
[httpd] 127.0.0.1 - - [25/Apr/2020:13:31:30 -0300] “POST /write?db=prueba_telegraf_mqtt_1 HTTP/1.1” 204 0 “-” “Telegraf/1.13.4” 380e8e9b-8712-11ea-8001-00e04c6871cd 53966
I created the “prueba_telegraf_mqtt_1” database using the influx.exe cmd. However, I am not sure how or where I can see the json that is being sent to the database, or if it is being received at all. How can I check this?
This is the telegraf.conf configuration
[[inputs.mqtt_consumer]]
servers = [“tcp://52.29.186.242:1883”]
topics = [
“esp/test”,
data_format = “json”
[[outputs.influxdb]]
(#) urls = [“udp://localhost:8086”] # UDP endpoint example
urls = [“http://127.0.0.1:8086”]
skip_database_creation = true
database = “prueba_telegraf_mqtt_1”
Thanks in advance for your help.
