Is there any configuration to disable the request rate limit so as not to present the error “429 Token is temporarily over quota. The Retry-After header describes when to try the write again.” in version 2.0 by the API?
Related topics
| Topic | Replies | Views | Activity | |
| Write to InfluxDB cloud fails with ApiException: (503) Reason: Service Unavailable; upstream connect error or disconnect/reset before headers. reset reason: connection failure | 48 | 4098 | October 18, 2021 | |
| Get unauthorized access when write to influxdb | 1 | 2516 | November 9, 2022 | |
| InfluxDb2 backup fails: failed to backup metadata...401 Unauthorized: unauthorized access | 15 | 8993 | January 29, 2025 | |
| Help: get "partial write: max-values-per-tag limit exceeded (500002/500000)" but "SHOW TAG VALUES CARDINALITY" is lower more | 0 | 900 | August 13, 2020 | |
| How to create a query for forecast.solar in inputs of telegraf | 17 | 1270 | May 2, 2023 |
