I have data (both /data/
and /wal/
directories) from an old v2 instance stored. I now have a v2 instance running with the same bucket as the old. I would like to merge the old data into the new.
I was trying to migrate the data storage from /var/lib to a separate folder. It turns out I moved the buckets over but did not properly re-configure Influx to save all new incoming data to these new file locations. So I now have two separate datasets where there is some overlap in data between the current /var/lib
folder and the original folder—see below, subdirectory 1433
. Is it possible to recombine the two different folders into a single congruent dataset without losing data from the overlapping file?
Thanks in advance.
X-Influxdb-Build: OSS
X-Influxdb-Version: v2.7.1
New instance directory:
NEW_DIR/engine/data/BUCKET_ID/autogen# ls -l
total 24
drwxr-x--- 3 influxdb influxdb 4096 Apr 2 22:50 1433
drwxr-x--- 3 influxdb influxdb 4096 Apr 15 20:16 1500
drwxr-x--- 3 influxdb influxdb 4096 Apr 15 20:16 1522
drwxr-x--- 3 influxdb influxdb 4096 May 1 18:48 1538
drwxr-x--- 3 influxdb influxdb 4096 May 1 18:48 1554
drwxr-x--- 3 influxdb influxdb 4096 May 3 19:15 1570
Old instance directory:
OLD_DIR/engine/data/BUCKET_ID/autogen# ls -l
total 168
drwxr-x--- 3 influxdb influxdb 4096 Nov 25 07:31 1003
drwxr-x--- 3 influxdb influxdb 4096 Nov 25 07:31 1016
drwxr-x--- 3 influxdb influxdb 4096 Nov 25 07:31 1029
drwxr-x--- 3 influxdb influxdb 4096 Nov 25 07:31 1060
drwxr-x--- 3 influxdb influxdb 4096 Nov 25 07:31 1073
drwxr-x--- 3 influxdb influxdb 4096 Nov 25 07:31 1086
drwxr-x--- 3 influxdb influxdb 4096 Nov 25 07:31 1099
drwxr-x--- 3 influxdb influxdb 4096 Nov 25 07:31 1112
drwxr-x--- 3 influxdb influxdb 4096 Nov 25 07:31 1125
drwxr-x--- 3 influxdb influxdb 4096 Nov 25 07:31 1138
drwxr-x--- 3 influxdb influxdb 4096 Nov 25 07:31 1151
drwxr-x--- 3 influxdb influxdb 4096 Nov 27 04:09 1164
drwxr-x--- 3 influxdb influxdb 4096 Jan 9 18:13 1177
drwxr-x--- 3 influxdb influxdb 4096 Jan 9 18:13 1190
drwxr-x--- 3 influxdb influxdb 4096 Jan 9 18:13 1207
drwxr-x--- 3 influxdb influxdb 4096 Jan 9 18:13 1221
drwxr-x--- 3 influxdb influxdb 4096 Jan 9 18:13 1235
drwxr-x--- 3 influxdb influxdb 4096 Jan 9 18:13 1249
drwxr-x--- 3 influxdb influxdb 4096 Feb 22 20:28 1263
drwxr-x--- 3 influxdb influxdb 4096 Feb 22 20:28 1277
drwxr-x--- 3 influxdb influxdb 4096 Feb 22 20:28 1292
drwxr-x--- 3 influxdb influxdb 4096 Feb 22 20:28 1307
drwxr-x--- 3 influxdb influxdb 4096 Feb 22 20:28 1322
drwxr-x--- 3 influxdb influxdb 4096 Feb 22 20:28 1337
drwxr-x--- 3 influxdb influxdb 4096 Mar 19 00:52 1352
drwxr-x--- 3 influxdb influxdb 4096 Mar 19 00:52 1365
drwxr-x--- 3 influxdb influxdb 4096 Mar 19 00:52 1380
drwxr-x--- 3 influxdb influxdb 4096 Mar 19 00:52 1395
drwxr-x--- 3 influxdb influxdb 4096 Mar 27 16:21 1410
drwxr-x--- 3 influxdb influxdb 4096 Mar 27 16:22 1433
drwxr-xr-x 3 influxdb influxdb 4096 Aug 1 2023 705
drwxr-xr-x 3 influxdb influxdb 4096 Aug 1 2023 717
drwxr-xr-x 3 influxdb influxdb 4096 Aug 1 2023 730
drwxr-xr-x 3 influxdb influxdb 4096 Aug 1 2023 743
drwxr-xr-x 3 influxdb influxdb 4096 Aug 1 2023 756
drwxr-xr-x 3 influxdb influxdb 4096 Aug 1 2023 769
drwxr-xr-x 3 influxdb influxdb 4096 Aug 1 2023 782
drwxr-x--- 3 influxdb influxdb 4096 Nov 25 07:31 938
drwxr-x--- 3 influxdb influxdb 4096 Nov 25 07:31 951
drwxr-x--- 3 influxdb influxdb 4096 Nov 25 07:31 964
drwxr-x--- 3 influxdb influxdb 4096 Nov 25 07:31 977
drwxr-x--- 3 influxdb influxdb 4096 Nov 25 07:31 990
