I need to merge the following 3 datasources ( GPS data → see code example ) into 1 output stream ( Join function? ), however i’m failing in getting the right query unfortunately.
The data needs to be merged to always have a ‘single’ Latitude/Longitude output ( for plotting purposes ) despite one of the datasources could be empty.
My starting point:
data = from(bucket: "kgnv_rd")
|> range(start: v.timeRangeStart, stop:v.timeRangeStop)
// Datasource 1
nmeaGNSS = data
|> filter(fn: (r) => r._measurement == "${DeviceID}" and (r._field == "NMEA2000_GNSS_Latitude" or r._field == "NMEA2000_GNSS_Longitude" ))
//|> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value")
// Datasource 2
nmeaHighfreq = data
|> filter(fn: (r) => r._measurement == "${DeviceID}" and (r._field == "NMEA2000_PosLatitude" or r._field == "NMEA2000_PosLongitude" ))
// |> pivot(rowKey:["_time"], columnKey: ["_field"], valueColumn: "_value")
// Datasource 3
standard = data
|> filter(fn: (r) => r._measurement == "${DeviceID}" and (r._field == "Latitude" or r._field == "Longitude" ))
|> yield()
data for example looks like ( only 2 sources available in dataset in this case ):
|> filter(fn: (r) => r._measurement == "${DeviceID}" and ( r._field == "NMEA2000_GNSS_Latitude" or r._field == "NMEA2000_GNSS_Longitude" or r._field == "NMEA2000_PosLongitude" or r._field == "NMEA2000_PosLatitude"or r._field == "Latitude" or r._field == "Longitude" ))
|> yield()
How could I achieve this? Hope someone can help me out in the right direction
Hi @bart1992,
Have you tried using a join()? I don’t think it will be too pretty but look something like this:
nmeaGNSS = data
// Datasource 2
nmeaHighfreq = data
// Datasource 3
standard = data
tmp = join(
tables: {nmeaGNSS: nmeaGNSS, nmeaHighfreq: nmeaHighfreq},
on: ["_time"],
join(tables: {tmp: tmp, standard: standard}, on: ["_time"])
|> yield(name: "combined")
Hi @Jay_Clifford,
Thanks for your response! I’ve tried your solution, but unfortunately it does not work. Since im not able to get it to work, i’ve started with only 2 data sources but also with only 2 sources i’m unable to join/merge the data.
The influxDB server keeps on crashing when performing the join function like :
// |> filter(fn: (r) => r._measurement == "${DeviceID}" and (r._field == "NMEA2000_GNSS_Latitude" or r._field == "NMEA2000_GNSS_Longitude" or r._field == "Latitude" or r._field == "Longitude" ))
// Datasource 1
nmeaGNSS = data
// Datasource 2
standard = data
join(tables: {nmeaGNSS: nmeaGNSS, standard: standard}, on: ["_time"])
|> yield()
error:
The joining on [_time] is probably causing issues, since the data is not exactly alligned in this time frame. Putting this function before the join does not seem to help :
|> truncateTimeColumn(unit: 10s)
|> yield()
Hope you have another solution/query which I can try?
Thanks,
