Based on documentation Join data with Flux I should have be able to join 3 streams however documentation says YES / NO if I am not mistaken…
Can I join 3 tables ?
The
join()function merges two or more input streams, whose values are equal on a set of common columns, into a single output stream. Flux allows you to join on any columns common between two data streams and opens the door for operations such as cross-measurement joins and math across measurements.
When I try to combine 2 streams (any combination with availability, quality or performance it just works), once I add third one it fails to return the value.
2 streams working OK
test = join(tables:{availability:availability, performance:performance}, on:["_start"])
test |> yield()
,result,table,_start,_value_availability,_value_performance
,,0,2020-01-23T02:30:00Z,87.47412008281573,0.5035971223021583
3 streams, server error
test = join(tables:{quality:quality, availability:availability, performance:performance}, on:["_start"])
test |> yield()
