Hi everyone,
I’m using influx 1.8. I am facing few issue regarding some measurements like when the agent runs the logs are displaying as data is inserted but when I try to check in database the data is not inserted and its effected for measurements which are having huge data.
Is there any measurement limit or any cache related config that needs to be changed.
As far as concerned for remaining measurements in the same database this issue is not effecting.
Any limit for record insertion in particular measurement.
Thanks for your response in advance.
