Hey,
I have a problem where I few py scripts running and sending data to my influxdb database (to the main server) all send to the same database with different measurements. Where the interval is 5 seconds?
I think that’s why I’m receiving the “Exception occurred” when running the script, the script is working but every moment the error comes. Below i will paste the py script
$ influx --version
InfluxDB shell version: 1.8.10
py script;
GNU nano 5.4 door.py *
#!/usr/bin/env python3
import time
import glob
import os
os.system(‘modprobe w1-gpio’)
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
frontRoomSmallDoor = 22
backSmallDoor = 23
garageMainDoor = 24
repeatDelay = 5 # change to 30 as per requesting
GPIO.setup(coolRoomSmallDoor, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
GPIO.setup(freezerSmallDoor, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
GPIO.setup(freezerMainDoor, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
from influxdb import InfluxDBClient
client = InfluxDBClient(host=‘192.168.31.234’, port=8086, username=‘user’, password=‘password^’, database=‘database’)
#client.get_list_database()
client.switch_database(‘database’)
while True:
csd = 0 print("front Small Door: ", end = "") if GPIO.input(coolRoomSmallDoor) > 0: print("Closed") else: print("Opened") csd = 1 fsd = 0 print("back Small Door: ", end = "") if GPIO.input(freezerSmallDoor) > 0: print("Closed") else: print("Opened") fsd = 1 fmd = 0 print("garage Main Door: ", end = "") if GPIO.input(freezerMainDoor) > 0: print("Closed") else: print("Opened") fmd = 1 # TODO send data to influx json_body = [ { "measurement": "doors", "tags": { "Device": "door-senor", "ID": "se" }, "fields": { "front_small": csd, "back_small": fsd, "garage_main": fmd, } } ] try: client.write_points(json_body) except Exception as e: print("Exception occured: ", e) time.sleep(repeatDelay)Exception occurred
the output;
front Small Door: Closed
back Small Door: Closed
garage Main Door: Closed
Exception occured: HTTPConnectionPool(host=‘192.168.31.234’, port=8086): Max retries exceeded with url: /write?db=dtmtelegrafdata (Caused by NewConnectionError(‘<urllib3.connection.HTTPConnection object at 0xb5d434d8>: Failed to establish a new connection: [Errno 111] Connection refused’))
Exception occured: HTTPConnectionPool(host=‘192.168.31.234’, port=8086): Max retries exceeded with url: /write?db=dtmtelegrafdata (Caused by NewConnectionError(‘<urllib3.connection.HTTPConnection object at 0xb5e06f88>: Failed to establish a new connection: [Errno 111] Connection refused’))
