Ive been running InfluxDB 2 on my VPS but I keep getting an internal server error. Although it works for a day or two, after a while I get this error which is then solved by simply restarting the file that saves the data to the db. Every 2 seconds, data gets written which other scripts read every 2 seconds. One that writes and many that read. This is the error that keeps popping up:
HTTP response body: {"code":"internal error","message":"unexpected error writing points to database: timeout"}.
Also msg="Recorder handler error" log_id=0TZkr_~000 error=timeout keeps popping up in the logs.
Any help or hint where to look is greatly appreciated.
Thank you
