I lost my access to an azure-based InfluxCloud account and am looking to restore access. I was using gmail auth to get into the bucket but sadly no longer have access to that email address. What’s the best way to reset the login credentials to regain control over the bucket?
Thanks!
Hello @sebito91,
Welcome back
Hmm for that I recommend reaching out to support. What was the old email associated with the account?
But I’ll try to ask internally too.
https://support.influxdata.com/s/
Thanks for the warm (return) welcome, and yes I’m happy to be back. The address is sborza@uchicago.edu and should be connected into the following:
[[outputs.influxdb_v2]]
urls = ["https://westeurope-1.azure.cloud2.influxdata.com"]
## Token for authentication.
token = "__mytoken__"
organization = "sebtest"
bucket = "tester"
Still working with Support on this one…doesn’t seem to be a straightforward ask unfortunately
Will keep you all updated!
