I added load1 rule similar to mem_alert_stream.tick
I have mem and cpu alerts. My dashboards show me load metrics and load alert generated with chronograf works as well (though it works in strange way; I get Critical host1 and then Ok host2 and it repeats while it is critical for host1).
So here is my alert rule, what can be wrong?
// Parameters
var info = 0.5
var warn = 0.7
var crit = 1
var infoSig = 2.5
var warnSig = 3
var critSig = 3.5
var period = 10s
var every = 10s
// Dataframe
var data = stream
|from()
.database('telegraf')
.retentionPolicy('autogen')
.measurement('system')
.groupBy('host')
|window()
.period(period)
.every(every)
|mean('load1')
.as('stat')
// Thresholds
var alert = data
|eval(lambda: sigma("stat"))
.as('sigma')
.keep()
|alert()
.id('{{ index .Tags "host"}}/load1')
.message('{{ .ID }}:{{ index .Fields "stat" }}')
.info(lambda: "stat" > info OR "sigma" > infoSig)
.warn(lambda: "stat" > warn OR "sigma" > warnSig)
.crit(lambda: "stat" > crit OR "sigma" > critSig)
// Alert
alert
.log('/tmp/load1_log.txt')
