Even when the timeseries (i.e tag-set) is different? Individually the timeseries values are arriving in time-sorted order in the line-protocol batch. Example to illustrate what I mean can be seen below. There is two series here:
- sensor,dimension=leakage,location=js,tag=sensor01,unit=raw
- sensor,dimension=pressure,location=js,tag=sensor01,unit=bar
And for the for timeseries number 1 here, the tick-script below windows over 15 seconds of data, not the specified 10 seconds.
Tick-script:
dbrp "test_kapacitor"."autogen"
stream
| from()
.measurement(sensor)
|window()
.period(10s)
.every(0s)
|httpOut(dump)
Line-protocol batch:
sensor,tag=sensor01,unit=bar,dimension=pressure,location=js value=17 0
sensor,tag=sensor01,unit=bar,dimension=pressure,location=js value=20 1000000000
sensor,tag=sensor01,unit=bar,dimension=pressure,location=js value=15 2000000000
sensor,tag=sensor01,unit=bar,dimension=pressure,location=js value=15 3000000000
sensor,tag=sensor01,unit=bar,dimension=pressure,location=js value=15 4000000000
sensor,tag=sensor01,unit=bar,dimension=pressure,location=js value=15 5000000000
sensor,tag=sensor01,unit=bar,dimension=pressure,location=js value=15 6000000000
sensor,tag=sensor01,unit=bar,dimension=pressure,location=js value=15 7000000000
sensor,tag=sensor01,unit=bar,dimension=pressure,location=js value=15 8000000000
sensor,tag=sensor01,unit=bar,dimension=pressure,location=js value=15 9000000000
sensor,tag=sensor01,unit=bar,dimension=pressure,location=js value=15 10000000000
sensor,tag=sensor01,unit=bar,dimension=pressure,location=js value=15 11000000000
sensor,tag=sensor01,unit=bar,dimension=pressure,location=js value=15 12000000000
sensor,tag=sensor01,unit=bar,dimension=pressure,location=js value=15 13000000000
sensor,tag=sensor01,unit=bar,dimension=pressure,location=js value=15 14000000000
sensor,tag=sensor01,unit=bar,dimension=pressure,location=js value=15 15000000000
sensor,tag=sensor01,unit=raw,dimension=leakage,location=js value=1700 0
sensor,tag=sensor01,unit=raw,dimension=leakage,location=js value=2000 1000000000
sensor,tag=sensor01,unit=raw,dimension=leakage,location=js value=1500 2000000000
sensor,tag=sensor01,unit=raw,dimension=leakage,location=js value=1500 3000000000
sensor,tag=sensor01,unit=raw,dimension=leakage,location=js value=1500 4000000000
sensor,tag=sensor01,unit=raw,dimension=leakage,location=js value=1500 5000000000
sensor,tag=sensor01,unit=raw,dimension=leakage,location=js value=1500 6000000000
sensor,tag=sensor01,unit=raw,dimension=leakage,location=js value=1500 7000000000
sensor,tag=sensor01,unit=raw,dimension=leakage,location=js value=1500 8000000000
sensor,tag=sensor01,unit=raw,dimension=leakage,location=js value=1500 9000000000
sensor,tag=sensor01,unit=raw,dimension=leakage,location=js value=1500 10000000000
sensor,tag=sensor01,unit=raw,dimension=leakage,location=js value=1500 11000000000
sensor,tag=sensor01,unit=raw,dimension=leakage,location=js value=1500 12000000000
sensor,tag=sensor01,unit=raw,dimension=leakage,location=js value=1500 13000000000
sensor,tag=sensor01,unit=raw,dimension=leakage,location=js value=1500 14000000000
sensor,tag=sensor01,unit=raw,dimension=leakage,location=js value=1500 15000000000
Results in following dumped output:
"series": [
"name": "sensor",
"columns": [
"time",
"dimension",
"location",
"tag",
"unit",
"value"
"values": [
"1970-01-01T00:00:06Z",
"pressure",
"js",
"sensor01",
"bar",
15
"1970-01-01T00:00:07Z",
"pressure",
"js",
"sensor01",
"bar",
15
"1970-01-01T00:00:08Z",
"pressure",
"js",
"sensor01",
"bar",
15
"1970-01-01T00:00:09Z",
"pressure",
"js",
"sensor01",
"bar",
15
"1970-01-01T00:00:10Z",
"pressure",
"js",
"sensor01",
"bar",
15
"1970-01-01T00:00:11Z",
"pressure",
"js",
"sensor01",
"bar",
15
"1970-01-01T00:00:12Z",
"pressure",
"js",
"sensor01",
"bar",
15
"1970-01-01T00:00:13Z",
"pressure",
"js",
"sensor01",
"bar",
15
"1970-01-01T00:00:14Z",
"pressure",
"js",
"sensor01",
"bar",
15
"1970-01-01T00:00:15Z",
"pressure",
"js",
"sensor01",
"bar",
15
"1970-01-01T00:00:00Z",
"leakage",
"js",
"sensor01",
"raw",
1700
"1970-01-01T00:00:01Z",
"leakage",
"js",
"sensor01",
"raw",
2000
"1970-01-01T00:00:02Z",
"leakage",
"js",
"sensor01",
"raw",
1500
"1970-01-01T00:00:03Z",
"leakage",
"js",
"sensor01",
"raw",
1500
"1970-01-01T00:00:04Z",
"leakage",
"js",
"sensor01",
"raw",
1500
"1970-01-01T00:00:05Z",
"leakage",
"js",
"sensor01",
"raw",
1500
"leakage",
"js",
"sensor01",
"raw",
1500
"leakage",
"js",
"sensor01",
"raw",
1500
"leakage",
"js",
"sensor01",
"raw",
1500
"leakage",
"js",
"sensor01",
"raw",
1500
"leakage",
"js",
"sensor01",
"raw",
1500
"leakage",
"js",
"sensor01",
"raw",
1500
"leakage",
"js",
"sensor01",
"raw",
1500
"leakage",
"js",
"sensor01",
"raw",
1500
"leakage",
"js",
"sensor01",
"raw",
1500
"leakage",
"js",
"sensor01",
"raw",
1500
