The upgrade docs in the version 1.6 guide is still displaying the information relevant to 1.5.
Is there any special steps to upgrade from 1.5.2, for example?
Thank you
Thank you
I don’t think there are any additional steps when going from 1.5.2 to 1.6, you only need to be careful if the version you are updating from uses the old inmem indexing.
I updated a 1.5 instance the other day with no issues, but of course it’s always best to back up any data and your config file first.
The release notes should help you work out if there are any breaking changes in updating.
