Dear InfluxData Community,
Over the past several weeks, we’ve seen weekly kernel panics on some of our production instances (Ubuntu 18.04, kernel 4.15 - 4.18); while those instances are massive & running several hundred processes, in all cases telegraf is part of the kernel stack trace. Have you ever seen this anywhere?
Best Regards
MarcV
June 25, 2019, 2:29pm
2
Hi @blackbird , welcome to the InfluxData community
the problems seem to start here .
[ 3886.400227] systemd-journald[815]: File /var/log/journal/ec2c616239e136c87dc2c667d62ce116/user-10018.journal corrupted or uncleanly shut down, renaming and replacing.
[ 3996.592835] systemd-journald[815]: File /var/log/journal/ec2c616239e136c87dc2c667d62ce116/user-1001.journal corrupted or uncleanly shut down, renaming and replacing.
[94332.438118] systemd-journald[815]: File /var/log/journal/ec2c616239e136c87dc2c667d62ce116/user-10035.journal corrupted or uncleanly shut down, renaming and replacing.
[163844.653572] systemd-journald[815]: File /var/log/journal/ec2c616239e136c87dc2c667d62ce116/user-10036.journal corrupted or uncleanly shut down, renaming and replacing.
[221444.001321] systemd-journald[815]: File /var/log/journal/ec2c616239e136c87dc2c667d62ce116/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
[242560.424787] systemd-journald[815]: File /var/log/journal/ec2c616239e136c87dc2c667d62ce116/user-10042.journal corrupted or uncleanly shut down, renaming and replacing.
[314896.122990] systemd-journald[815]: File /var/log/journal/ec2c616239e136c87dc2c667d62ce116/user-10051.journal corrupted or uncleanly shut down, renaming and replacing.
[319441.760645] systemd-journald[815]: File /var/log/journal/ec2c616239e136c87dc2c667d62ce116/user-10004.journal corrupted or uncleanly shut down, renaming and replacing.
[823517.719189] audit: audit_backlog=4097 > audit_backlog_limit=4096
[823517.719190] audit: audit_lost=1 audit_rate_limit=0 audit_backlog_limit=4096
[823517.723182] audit: audit_backlog=4097 > audit_backlog_limit=4096
[823517.723183] audit: audit_lost=2 audit_rate_limit=0 audit_backlog_limit=4096
[823517.723192] audit: audit_backlog=4097 > audit_backlog_limit=4096
[823517.723195] audit: audit_lost=3 audit_rate_limit=0 audit_backlog_limit=4096
[823517.727189] audit: audit_backlog=4097 > audit_backlog_limit=4096
[823517.727190] audit: audit_lost=4 audit_rate_limit=0 audit_backlog_limit=4096
[823517.727192] audit: audit_backlog=4097 > audit_backlog_limit=4096
[823517.727193] audit: audit_backlog=4097 > audit_backlog_limit=4096
[2311488.107255] PANIC: double fault, error_code: 0x0
have you found the cause of this ?
best regards
