This is an important use case for us.
How can one write a stream tickscript which will aggregate and combine collection of multiple (instance#) of the same Process into one and calculate average Percent_Processor_Time.
Example: measurement Process has instance tag which stores name of the .exe like:
instance, Percent_Processor_Time
WmiPrvSE#1, 1.0
WmiPrvSE#2, 0.1
WmiPrvSE#3, 0.3
Chrome#1, 1.0
Chrome#2, 0.0
Chrome#3, 2.0
Goal is to combine same Process into one and get the Average:
WmiPrvSE, 0.46
Chrome, 1.00
I tried the creating a stream tickscript but it was not giving any output.
So i tried batch and it is yielding an output but not grouping the instance into one.
Do i have to use regex explicitly on instance?
Objective is to get .exe cpu usage divided by the number of cpu present on the server.
// Get Percent_Processor_Time for each process
var process = batch
|query('SELECT Percent_Processor_Time as cpu_time FROM "test"."autogen"."Process"')
.period(1m)
.every(1m)
.groupBy('instance', 'host')
|mean('cpu_time')
.as('cpu_time')
// This is to get number of cpus from each host
var system = batch
|query('SELECT n_cpus as n_cpus FROM "test"."autogen"."system"')
.period(15m)
.every(1m)
.groupBy('host')
|last('n_cpus')
.as('n_cpus')
var joined_data = process
|join(system)
.as('process', 'system')
.on('instance')
.tolerance(20s)
var perform = joined_data
|eval(lambda: "process.cpu_time" / "system.n_cpus")
.as('mean')
.keep()
|influxDBOut()
.database('test')
.measurement('perform')
