we would like to make cluster status data available to some TICK scripts like the script handling procstat data from Telegraf.
Is it possible to read such status data from sideload and have dedicated kapacitor TICK to actually write such data using HTTP?
The sideload needs a certain structure and performs a GET request, Httpout can make data available using Kapacitor which can be read using HTTP GET but the structure seems not to match for sideload, and seems not possible to change the structure.
I guess it is doable with exec and making script that does things, but native HTTP would sound like a much cleaner solution.
Best Regards,
Menno
