Hello! Currently kapacitor makes an influx subscription for all data from all measurements . This is quite expensive because if i just have one stream tickscript picking data from one measurement , influx will still push all data from all measurements to kapacitor making it highly network intensive . Is there a way to push only the required data from influx to kapacitor for stream tickscripts?
I am also facing the same issue, need some explanation @staff
@Anaisdg would you be able to help out with this?
