are there any kapacitor metrics store in influxdb?
Would it make sense in order to monitor the performance of kapacitor?
Yes, Kapacitor will emit metrics into a stream with database and retention policy of _kapacitor.autogen by default.
Then you can decide what to do with the metrics, but typically you can send them to InfluxDB via a simple task:
stream
|from()
.database('_kapacitor')
.retentionPolicy('autogen')
|influxDBOut()
See the [stats] config section for changing things like the interval etc.
nice, thanks very much.
