Kapacitor HTTPPOST content-type config in yml
Kapacitor 1.5.2
I’m trying to configure the HTTPPOST parameters in YML config, so far the following settings are working fine:
KAPACITOR_HTTPPOST_0_ENDPOINT=Eventmng
KAPACITOR_HTTPPOST_0_URL=https://events-json.ca.inet:9090
KAPACITOR_HTTPPOST_0_ALERT_TEMPLATE_FILE=/var/lib/kapacitor/post-event.tmpl
KAPACITOR_HTTPPOST_0_BASIC_AUTH_USERNAME=user
KAPACITOR_HTTPPOST_0_BASIC_AUTH_PASSWORD=user1234
But for this one, it’s not being register at all:
KAPACITOR_HTTPPOST_0_HEADERS_CONTENT_TYPE=application/json
the setting is not showing with the kapacitord config command. I tried many ways that I could find as example on the net, but nothing works.
Any idea?
Thanks, Eric
I’m also stuck on the same issue.
Does anyone know of a way to achieve passing header values from environment variable or from sideloading a file?
For sideloading, there’s another issue someone else raised here: TICK Script HttpPost Headers
So basically:
  • Setting httppost headers from env variable does not work
  • Setting httppost headers from sideloaded variables also does not work
Hi srijan,
the only way I could go around this issue is to create an external conf file with the httppost parameters and create a volume that will replace the actual conf in the container:
in the YML of the Kapacitor:
volumes:
  • /localpath/MyConfFile.conf:/etc/kapacitor/kapacitor.conf:ro
MyConfFile.conf:
[smtp]
enabled = true
host = “hostname”
port = 465
username = “username”
password = “password”
[[httppost]]
endpoint = “MYLabel”
url = “https://events-json.ca.inet:9090”
headers = { Content-Type = “application/json; charset=UTF-8” }
alert-template-file = “/etc/kapacitor/post-event.tmpl”
Regards
