Is there way of using httppost as a topic-handler?
I would like to use it with the alert-template
I only see post in kapacitor 1.4rc1
I think i figured it out
post.yaml
topic: 'test_alerts'
kind: 'post'
options:
endpoint: "test"
And then in the kapacitor config i can configure test endpoint for httppost
Hi.
I would just like to use post. not httppost. is there a way to give an endpoint that way.?
and how do i use it as a json, since i do not intend to use yaml.
