How to POST json when the alert occur , Kapacitor/Chronogaf?
When an alert happen i would like to do
"curl -X PUT "http://192.168.0.1/ssapi/zb/dev/1/ldev/smartplug/data/onoff" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"value\": false}""
or simply post some json to http://192.168.1.73/ssapi/zb/dev/1/ldev/smartplug/data/onoff
Where should the above information go ?
Hi @BhanuKiran
You can define an httppost handler for Kapacitor as follows:
[[httppost]]
  endpoint = "onoff"
  url = "http://192.168.0.1/ssapi/zb/dev/1/ldev/smartplug/data/onoff"
  headers = { "Content-Type" = "application/json" }
  alert-template = "{{.Message}}:{{range .Data.Series}}{{.Tags}},{{range .Values}}{{.}}{{end}}{{end}}"
  row-template = "{{.Name}} host={{index .Tags \"host\"}}{{range .Values}} {{index . "time"}} {{index . "value"}}{{end}}"
This can then be utilised in your TICKscript:
|alert()
  .post()
    .endpoint('onoff')
You can find out more about this within our documentation.
Thanks,
Hope this helps!
Hi @rawkode,
I really appreciate your response. I am completely new to these and went through the documentation but couldn’t understand the nuances between alert-template and row-template.
In my case , I just need to send json { "value": false} ,but i don’t understand where( alert-template/row-template) and how to put it ?
Hey @BhanuKiran,
If you don’t need a template message, you can hard code what you require:
alert-template = "{ \"value\": false }"
Hi @rawkode,
I had a problem when i placed the above script in Kapacitor configuration file. I am using the sandbox and the kapacitor Docker is exiting exiting instantly after restarting the sandbox and i have posted the question in here.
