Kapacitor Client Libraries?
Currently the only Kapacitor client is written in Golang and is undocumented. The API is documented.
If you are looking for an easier way to use kapacitor I would encourage you to check out the Kapacitor UI in Chronograf.
The Kapacitor Go client is documented on godoc.org.
