I am currently receiving data from a kafka topic to the telegraf kafka_consumer plugin.
The structure of my JSON looks like this:
type: "FeatureCollection",
metadata: {
generated: Long Integer,
url: String,
title: String,
api: String,
count: Integer,
status: Integer
bbox: [
minimum longitude,
minimum latitude,
minimum depth,
maximum longitude,
maximum latitude,
maximum depth
features: [
type: "Feature",
properties: {
mag: Decimal,
place: String,
time: Long Integer,
updated: Long Integer,
tz: Integer,
url: String,
detail: String,
felt:Integer,
cdi: Decimal,
mmi: Decimal,
alert: String,
status: String,
tsunami: Integer,
sig:Integer,
net: String,
code: String,
ids: String,
sources: String,
types: String,
nst: Integer,
dmin: Decimal,
rms: Decimal,
gap: Decimal,
magType: String,
type: String
geometry: {
type: "Point",
coordinates: [
longitude,
latitude,
depth
I manage to retrieve some of the information I’m interested in, but unfortunately no matter how big the Features array is, the parsing only retrieves one element
Here is my telegraf.conf file:
[agent]
interval = "10s"
## Rounds collection interval to 'interval'
round_interval = true
## Telegraf will send metrics to outputs in batches of at most
## metric_batch_size metrics.
## This controls the size of writes that Telegraf sends to output plugins.
metric_batch_size = 1000
## Maximum number of unwritten metrics per output. Increasing this value
## allows for longer periods of output downtime without dropping metrics at the
## cost of higher maximum memory usage.
metric_buffer_limit = 10000
collection_jitter = "0s"
## Default flushing interval for all outputs. Maximum flush_interval will be
## flush_interval + flush_jitter
flush_interval = "10s"
## Jitter the flush interval by a random amount. This is primarily to avoid
## large write spikes for users running a large number of telegraf instances.
## ie, a jitter of 5s and interval 10s means flushes will happen every 10-15s
flush_jitter = "0s"
## Collected metrics are rounded to the precision specified. Precision is
## specified as an interval with an integer + unit (e.g. 0s, 10ms, 2us, 4s).
## Valid time units are "ns", "us" (or "µs"), "ms", "s".
## By default or when set to "0s", precision will be set to the same
## timestamp order as the collection interval, with the maximum being 1s:
## ie, when interval = "10s", precision will be "1s"
## when interval = "250ms", precision will be "1ms"
## Precision will NOT be used for service inputs. It is up to each individual
## service input to set the timestamp at the appropriate precision.
precision = "0s"
## Override default hostname, if empty use os.Hostname()
hostname = ""
omit_hostname = false
# OUTPUT PLUGINS #
# # Configuration for sending metrics to InfluxDB 2.0
[[outputs.influxdb_v2]]
## ex: urls = ["https://us-west-2-1.aws.cloud2.influxdata.com"]
urls = ["http://127.0.0.1:8086"]
## Token for authentication.
token = $INFLUX_TOKEN
## Organization is the name of the organization you wish to write to.
organization = "earthWatch"
bucket = "telegraf"
[[inputs.kafka_consumer]]
## Kafka brokers.
brokers = ["localhost:9092"]
## Topics to consume.
topics = ["general-events"]
## Maximum length of a message to consume, in bytes (default 0/unlimited);
## larger messages are dropped
max_message_len = 0
data_format="json"
json_query = "features.#.properties"
json_string_fields = ["place", "url", "detail", "alert", "status", "net", "code", "ids", "sources", "types", "magType", "type", "mag", "time", "updated", "tz", "felt", "cdi", "mmi", "tsunami", "sig", "nst", "dmin", "rms", "gap"]
