I have a csv file that contains historical measurements that I am trying to write to InfluxDB.
I have converted the timestamps to that which InfluxDB seems to like if I enter things manually.
Example data from CSV:
1490252400000000000,62
1490338800000000000,23
Timestamp and measurement, pretty simple.
I can manually insert things as such:
> insert portcount ports=62 1490252400000000000
> select * from portcount
time ports
1490252400000000000 62
My python script simple runs through each line of the csv and extracts what is needed and then should write the points to the database.
Example:
import influxdb
from influxdb import client as influxdb
portcount = {}
with open(r'portcountlog.csv', 'r') as h:
for line in h:
log = line.strip('\n').split(',')
loglist = []
logentry = {}
logentry['measurement'] = "portcount"
logentry['time'] = log[0]
logentry['fields'] = {}
logentry['fields']['ports'] = log[1]
loglist.append(logentry)
print (loglist)
db.write_points(loglist)
When I try running it I can see the data is correct for the line but it seems as though something in the client is trying generate its own timestamp or something?
[user@itnetops scripts]$ python oldportcounts.py
[{'fields': {'ports': '2\r'}, 'time': '1489647600000000000', 'measurement': 'portcount'}]
Traceback (most recent call last):
File "oldportcounts.py", line 26, in <module>
File "/usr/lib/python2.7/site-packages/influxdb/client.py", line 456, in write_points
tags=tags, protocol=protocol)
File "/usr/lib/python2.7/site-packages/influxdb/client.py", line 506, in _write_points
protocol=protocol
File "/usr/lib/python2.7/site-packages/influxdb/client.py", line 292, in write
data = make_lines(data, precision).encode('utf-8')
File "/usr/lib/python2.7/site-packages/influxdb/line_protocol.py", line 160, in make_lines
_convert_timestamp(point['time'], precision)
File "/usr/lib/python2.7/site-packages/influxdb/line_protocol.py", line 22, in _convert_timestamp
timestamp = parse(timestamp)
File "/usr/lib/python2.7/site-packages/dateutil/parser.py", line 1168, in parse
return DEFAULTPARSER.parse(timestr, **kwargs)
File "/usr/lib/python2.7/site-packages/dateutil/parser.py", line 578, in parse
if cday > monthrange(cyear, cmonth)[1]:
File "/usr/lib64/python2.7/calendar.py", line 121, in monthrange
day1 = weekday(year, month, 1)
File "/usr/lib64/python2.7/calendar.py", line 113, in weekday
return datetime.date(year, month, day).weekday()
OverflowError: signed integer is greater than maximum
Is it trying to convert the timestamp I provided? It shouldn’t have to convert since it is in the format that InfluxDB uses? Any suggestions or advice on getting this to work?
