Over at the Eclipse IoT Ditto Project they are currently thinking about integrating a Timeseries Database into the Ditto-Projects backend infrastructure. Maybe some of you might want to take a look at the issue on github and bring in InfluxDB as an alternative?
Main concerns are authorization, which is handled in ditto and needs to be translated / applied. Probably using tags. And of course the mapping between the ditto protocol and influxdb schema.
This thread may be used as a place to discuss this from the influxdata point of view. Would this be an interesting use-case / integration?
I’m hoping to reach some folks of influxdata or someone from the community with deep understanding of the influxdata platform to analyze the potential of this
