I´ve setup a IR-eye that collects data from a Kamstrup Multical 601 Heatmeter (water) using GPIO´s on my Raspberry Pi2 and a script “automated” with Cron.
As Im not a coder I have found a script that sends data to Domoticz. I want the script to send the collected data to my InfluxDB. I´ve tried to replace the IP and port definitions for Domoticz in script with the IP and port for my influxDB installation but that doesnt work. Iv´e tried using the InfluxDB HTTP API curl -i -XPOST 'http://localhost:8086/write?db=mydb' --data-binary 'cpu_load_short,host=server01,region=us-west value=0.64 1434055562000000000' in the script but also with errors.
I would appreciate any help I can get to get this working, (have been struggling with this for a long time
Thank you very much.
#!/usr/bin/python
from __future__ import print_function
# You need pySerial
import serial
import math
import sys
import datetime
import json
import urllib
import urllib.request
import codecs
reader = codecs.getreader("utf-8")
domoip = "192.168.1.XX"
domoport = "8080"
debug = 1
kamstrup_MC601_var = { # Decimal Number in Command
0x003C: "Heat Energy (E1)", #60
0x0050: "Power", #80
0x0056: "Temp1", #86
0x0057: "Temp2", #87
0x0059: "Tempdiff", #89
0x004A: "Flow", #74
0x0044: "Volume", #68
0x008D: "MinFlow_M", #141
0x008B: "MaxFlow_M", #139
0x008C: "MinFlowDate_M", #140
0x008A: "MaxFlowDate_M", #138
0x0091: "MinPower_M", #145
0x008F: "MaxPower_M", #143
0x0095: "AvgTemp1_M", #149
0x0096: "AvgTemp2_M", #150
0x0090: "MinPowerDate_M", #144
0x008E: "MaxPowerDate_M", #142
0x007E: "MinFlow_Y", #126
0x007C: "MaxFlow_Y", #124
0x007D: "MinFlowDate_Y", #125
0x007B: "MaxFlowDate_Y", #123
0x0082: "MinPower_Y", #130
0x0080: "MaxPower_Y", #128
0x0092: "AvgTemp1_Y", #146
0x0093: "AvgTemp2_Y", #147
0x0081: "MinPowerDate_Y", #129
0x007F: "MaxPowerDate_Y", #127
0x0061: "Temp1xm3", #97
0x006E: "Temp2xm3", #110
0x0071: "Infoevent", #113
0x03EC: "HourCounter", #1004
units = {
0: '', 1: 'Wh', 2: 'kWh', 3: 'MWh', 4: 'GWh', 5: 'j', 6: 'kj', 7: 'Mj',
8: 'Gj', 9: 'Cal', 10: 'kCal', 11: 'Mcal', 12: 'Gcal', 13: 'varh',
14: 'kvarh', 15: 'Mvarh', 16: 'Gvarh', 17: 'VAh', 18: 'kVAh',
19: 'MVAh', 20: 'GVAh', 21: 'kW', 22: 'kW', 23: 'MW', 24: 'GW',
25: 'kvar', 26: 'kvar', 27: 'Mvar', 28: 'Gvar', 29: 'VA', 30: 'kVA',
31: 'MVA', 32: 'GVA', 33: 'V', 34: 'A', 35: 'kV',36: 'kA', 37: 'C',
38: 'K', 39: 'l', 40: 'm3', 41: 'l/h', 42: 'm3/h', 43: 'm3xC',
44: 'ton', 45: 'ton/h', 46: 'h', 47: 'hh:mm:ss', 48: 'yy:mm:dd',
49: 'yyyy:mm:dd', 50: 'mm:dd', 51: '', 52: 'bar', 53: 'RTC',
54: 'ASCII', 55: 'm3 x 10', 56: 'ton x 10', 57: 'GJ x 10',
58: 'minutes', 59: 'Bitfield', 60: 's', 61: 'ms', 62: 'days',
63: 'RTC-Q', 64: 'Datetime'
def crc_1021(message):
poly = 0x1021
reg = 0x0000
for byte in message:
mask = 0x80
while(mask > 0):
reg<<=1
if byte & mask:
reg |= 1
mask>>=1
if reg & 0x10000:
reg &= 0xffff
reg ^= poly
return reg
# Byte values which must be escaped before transmission
escapes = {
0x06: True,
0x0d: True,
0x1b: True,
0x40: True,
0x80: True,
# And here we go....
class kamstrup(object):
def __init__(self, serial_port):
self.debug_fd = open("/tmp/_kamstrup", "a")
self.debug_fd.write("\n\nStart\n")
self.debug_id = None
self.ser = serial.Serial(
port = serial_port,
baudrate = 1200,
timeout = 5.0,
bytesize = serial.EIGHTBITS,
parity = serial.PARITY_NONE,
stopbits = serial.STOPBITS_TWO)
# xonxoff = 0,
# rtscts = 0)
# timeout = 20
def debug(self, dir, b):
for i in b:
if dir != self.debug_id:
if self.debug_id != None:
self.debug_fd.write("\n")
self.debug_fd.write(dir + "\t")
self.debug_id = dir
self.debug_fd.write(" %02x " % i)
self.debug_fd.flush()
def debug_msg(self, msg):
self.debug_id = "Msg"
self.debug_fd.write("Msg\t" + msg)
def wr(self, b):
b = bytearray(b)
self.debug("Wr", b);
self.ser.write(b)
def rd(self):
a = self.ser.read(1)
if len(a) == 0:
self.debug_msg("Rx Timeout")
return None
b = bytearray(a)[0]
self.debug("Rd", bytearray((b,)));
return b
def send(self, pfx, msg):
b = bytearray(msg)
b.append(0)
b.append(0)
c = crc_1021(b)
b[-2] = c >> 8
b[-1] = c & 0xff
c = bytearray()
c.append(pfx)
for i in b:
if i in escapes:
c.append(0x1b)
c.append(i ^ 0xff)
else:
c.append(i)
c.append(0x0d)
self.wr(c)
def recv(self):
b = bytearray()
while True:
d = self.rd()
if d == None:
return None
if d == 0x40:
b = bytearray()
b.append(d)
if d == 0x0d:
break
c = bytearray()
i = 1;
while i < len(b) - 1:
if b[i] == 0x1b:
v = b[i + 1] ^ 0xff
if v not in escapes:
self.debug_msg(
"Missing Escape %02x" % v)
c.append(v)
i += 2
else:
c.append(b[i])
i += 1
if crc_1021(c):
self.debug_msg("CRC error")
return c[:-2]
def readvar(self, nbr):
# I wouldn't be surprised if you can ask for more than
# one variable at the time, given that the length is
# encoded in the response. Havn't tried.
self.send(0x80, (0x3f, 0x10, 0x01, nbr >> 8, nbr & 0xff))
b = self.recv()
if b == None:
return (None, None)
if b[0] != 0x3f or b[1] != 0x10:
return (None, None)
if b[2] != nbr >> 8 or b[3] != nbr & 0xff:
return (None, None)
if b[4] in units:
u = units[b[4]]
else:
u = None
# Decode the mantissa
x = 0
for i in range(0,b[5]):
x <<= 8
x |= b[i + 7]
# Decode the exponent
i = b[6] & 0x3f
if b[6] & 0x40:
i = -i
i = math.pow(10,i)
if b[6] & 0x80:
i = -i
x *= i
if False:
# Debug print
s = ""
for i in b[:4]:
s += " %02x" % i
s += " |"
for i in b[4:7]:
s += " %02x" % i
s += " |"
for i in b[7:]:
s += " %02x" % i
print(s, "=", x, units[b[4]])
return (x, u)
if __name__ == "__main__":
import time
try:
comport = sys.argv[1]
except IndexError:
print("Device required. Example: /dev/ttyUSB0")
sys.exit()
# Previous Script had multiple arguments, commented this out for different usage
#command = int( sys.argv[2], 0)
try:
index = str( sys.argv[2] )
except IndexError:
print("Domoticz variables required. This script can not be executed without it")
sys.exit()
index = index.split(',')
if debug > 0:
print("Parameter specified: ")
for i in index:
print("+ " + i)
foo = kamstrup( comport )
heat_timestamp=datetime.datetime.strftime(datetime.datetime.today(), "%Y-%m-%d %H:%M:%S" )
# This command seems to have different outputs, left out for that.
# kamstrup_402_var = int(kamstrup_402_var * 1000)
print ("===========================================================")
print ("Kamstrup Multical 601 serial optical data received: %s" % heat_timestamp)
print ("Meter vendor/type: Kamstrup M601")
print ("---------------------------------------------------------------------------------------")
for i in kamstrup_MC601_var:
x,u = foo.readvar(i)
r = 0
print("%-25s" % kamstrup_MC601_var[i], x, u)
for y in index:
paramater = y.split(':')
idx = int(paramater[0],0)
dcNr = int(paramater[1],0)
opt = int(paramater[2],0)
try:
compare_idx = int(paramater[3],0)
except IndexError:
compare_idx = 0
# If decimal number matches the command given as argv[2]
if i == dcNr:
value = round(x,2)
# Retrieve devicename and devicedata
requestGet = ( "http://" + str(domoip) + ":" + str(domoport) + "/json.htm? type=devices&rid=" + str(idx) )
device_data = json.load(reader(urllib.request.urlopen(requestGet)))
device_name = device_data['result'][0]['Name']
device_value = device_data['result'][0]['Data']
if debug > 0:
print("+ Last stored value for device: " + device_name + " was " + device_value)
if debug > 0:
print("+ Processing parameter: " + str(y) + "")
# 0 = Update current
# 1 = Substraction
# 2 = Addition
if opt == 0:
# Submit the current value to the device
if debug > 0:
print(" + F" + str(opt) + " Debug: Overwrite: " + str(device_name) + " (idx: " + str(idx) + ") with latest value: " + str(value))
dummyvar = 0
elif opt == 1:
if compare_idx > 0:
requestGet = ( "http://" + str(domoip) + ":" + str(domoport) + "/json.htm?type=devices&rid=" + str(compare_idx) )
device_compare_data = json.load(reader(urllib.request.urlopen(requestGet)))
device_compare_name = device_compare_data['result'][0]['Name']
device_compare_value = device_compare_data['result'][0]['Data']
device_compare_value = device_compare_value.split(' ')
device_compare_value = device_compare_value[0]
diff = float(value) - float(device_compare_value)
diff = round(diff,2)
if debug > 0:
print(" + F" + str(opt) + " Debug: Substract " + str(device_compare_value) + " (idx:" + str(compare_idx) + ") from " + str(value) + " (idx:" + str(idx) + ") = " + str(diff) )
value = diff
elif opt == 2:
if compare_idx > 0:
device_value = device_value.split(' ')
device_value = device_value[0]
addup = float(diff) + float(device_value)
addup = round(addup,2)
if debug > 0:
print(" + F" + str(opt) + " Debug: Addition " + str(device_value) + " (idx:" + str(idx) + ") + " + str(diff) + " (" + str(value) + " (idx:" + str(idx) + ") - " + str(device_compare_value) + " (idx:" + str(compare_idx) + ")) = " + str(addup) )
value = addup
# Upload the current value to the device
print(" + F" + str(opt) + " Submit value " + str(value) + " to '" + str(device_name) + "' (idx: " + str(idx) + ")")
requestPost = ( "http://" + str(domoip) + ":" + str(domoport) + "/json.htm?type=command¶m=udevice&idx=" + str(idx) + "&svalue=" + str(value) )
#print(requestPost)
resultPost = urllib.request.urlopen(requestPost)
print ("End data received: %s" % heat_timestamp)
print ("=======================================================================================")
