I’m installing influxdb on linux and I’m getting this error after running
$sudo systemctl status influxdb
influxdb.service - InfluxDB is an open-source, distributed, time series database
Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Thu 2019-01-03 16:04:24 IST; 7min ago
Docs: InfluxDB OSS 2.6 Documentation
Process: 3596 ExecStart=/usr/bin/influxd -config /etc/influxdb/influxdb.conf $INFLUXD_OPTS (code=exited, status=1/FAILURE)
Main PID: 3596 (code=exited, status=1/FAILURE)
Jan 03 16:04:23 noam-AHV systemd[1]: influxdb.service: Failed with result ‘exit-code’.
Jan 03 16:04:24 noam-AHV systemd[1]: influxdb.service: Service hold-off time over, scheduling restart.
Jan 03 16:04:24 noam-AHV systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
Jan 03 16:04:24 noam-AHV systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
Jan 03 16:04:24 noam-AHV systemd[1]: influxdb.service: Start request repeated too quickly.
Jan 03 16:04:24 noam-AHV systemd[1]: influxdb.service: Failed with result ‘exit-code’.
Jan 03 16:04:24 noam-AHV systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
noam@noam-AHV:/var/log$ sudo systemctl status influxdb
● influxdb.service - InfluxDB is an open-source, distributed, time series database
Active: failed (Result: exit-code) since Thu 2019-01-03 16:04:24 IST; 11min ago
any ideas??
