[root@myownhost-rybs ~]# systemctl status -l influxdb.service
● influxdb.service - InfluxDB is an open-source, distributed, time series database
Loaded: loaded (/usr/lib/systemd/system/influxdb.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Wed 2023-01-11 23:03:48 +08; 5min ago
Docs: InfluxDB OSS 2.6 Documentation
Process: 7877 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh (code=exited, status=0/SUCCESS)
Main PID: 7878 (code=exited, status=1/FAILURE)
Jan 11 23:03:48 myownhost-rybs influxd-systemd-start.sh[7877]: ts=2023-01-11T15:03:48.367976Z lvl=info msg=“InfluxDB starting” log_id=0fKL_uZl000 version=1.8.10 branch=1.8 commit=688e697c51fd
Jan 11 23:03:48 myownhost-rybs influxd-systemd-start.sh[7877]: ts=2023-01-11T15:03:48.368001Z lvl=info msg=“Go runtime” log_id=0fKL_uZl000 version=go1.13.8 maxprocs=1
Jan 11 23:03:48 myownhost-rybs influxd-systemd-start.sh[7877]: Merging with configuration at: /etc/influxdb/influxdb.conf
Jan 11 23:03:48 myownhost-rybs influxd-systemd-start.sh[7877]: InfluxDB started
Jan 11 23:03:48 myownhost-rybs systemd[1]: Started InfluxDB is an open-source, distributed, time series database.
Jan 11 23:03:48 myownhost-rybs influxd-systemd-start.sh[7877]: run: open server: listen: listen tcp 127.0.0.1:8088: bind: address already in use
Jan 11 23:03:48 myownhost-rybs systemd[1]: influxdb.service: main process exited, code=exited, status=1/FAILURE
Jan 11 23:03:48 myownhost-rybs systemd[1]: Unit influxdb.service entered failed state.
Jan 11 23:03:48 myownhost-rybs systemd[1]: influxdb.service failed.
