Hi, I’m trying to install Influxdb on w10 but after have changed the configuration file from the browser (firefox) I’m not able connect the DB due that the reply to Http://localhost:8086 reply with" 404 page not found" error . Any suggestion ?
Thanks. Roberto
From version1.3, the web client of influxdb is deprecated. You can either use CLI or Chronograf to explore your DB
