I have the following database and measurements I am trying to insert from command line:
Database: polls
Measurement: nodeMemory
Field or tag (only one): NodeID=1
values: (this will be a variable named $nodemem1): 1921024000
I run the following command:
influx -database ‘polls’ -execute ‘insert nodeMemory,NodeID=1, values=1921024000’
I get the following error:
ERR: {“error”:“unable to parse ‘nodeMemory,NodeID=1, values=1921024000’: missing tag key”}
I figured out what I need for the inserts with static values, now I just need to know how to enter a variable in the values:
influx -database ‘polls’ -execute ‘insert nodeMemory,NodeID=1,server=server01 values=“$nodemem1”’
But I get the following error:
ERR: {“error”:“unable to parse ‘nodeMemory,NodeID=1,server=server01 values=$nodemem1’: invalid boolean”}
Anaisdg
November 12, 2023, 8:42am
3
Hello @skinfrakki ,
Thank you for sharing part of your solution. Unfortunately, you can insert a variable with line protocol. It must be the actual value.
