# Running on almalinux
(.venv) [vagrant@localhost latest]$ ./influxdb3 --version
influxdb3 3.1.0, revision 482dd8aac580c04f37e8713a8fffae89ae8bc264
I am trying to insert multiple points at once using python in a single write by means of the schedule trigger (every 5m).
Looking at the documentation for influxdb_client_3 write:
InfluxDBClient3.write
Writes a record or a list of records to InfluxDB.
Parameters
record(record or list): A record or list of records to write. A record can be aPointobject, a dict that represents a point, a line protocol string, or aDataFrame.
It indicates that the record parameter can take a list of points - but I am noticing that whenever I invoke the write with a list of points, only one point is being created, the very last one. The program that I have written to test this is as follows:
#!/usr/bin/env python3
from influxdb_client_3 import Point, InfluxDBClient3
from datetime import datetime
def process_scheduled_call(influxdb3_local, call_time, args=None):
points = list()
for i in range(10):
point = Point("home").tag("room", "Kitchen").field("temp", 21.5).field("hum", i)
points.append(point)
with InfluxDBClient3(host=f"http://127.0.0.1:8181",
database=f"mymetrics",
token="apiv3_C1GRsLP9rwhhKgc35UMTCO9fJfmv9dM0LXbJcqwEnuadI0pHNt--8hRa1wOJMW0k-J3mZIKlIumVprfn2pK28A") as client:
client.write(points)
From the output below you can see that hum only shows the value of 9, where I was expecting to see 10 rows with the hum value shown from 0-9.
(.venv) [vagrant@localhost latest]$ ./influxdb3 query --host http://localhost:8181 --database mymetrics --token ${MYTOKEN} "select * from home order by time"
| hum | room | temp | time |
| 9 | Kitchen | 21.5 | 2025-06-15T13:30:00.031321967 |
| 9 | Kitchen | 21.5 | 2025-06-15T13:35:00.009734678 |
| 9 | Kitchen | 21.5 | 2025-06-15T13:40:00.012950666 |
| 9 | Kitchen | 21.5 | 2025-06-15T13:45:00.016408837 |
| 9 | Kitchen | 21.5 | 2025-06-15T13:50:00.014682968 |
| 9 | Kitchen | 21.5 | 2025-06-15T13:55:00.015578279 |
| 9 | Kitchen | 21.5 | 2025-06-15T14:00:00.013806979 |
| 9 | Kitchen | 21.5 | 2025-06-15T14:05:00.006781452 |
| 9 | Kitchen | 21.5 | 2025-06-15T14:10:00.012360783 |
| 9 | Kitchen | 21.5 | 2025-06-15T14:15:00.014129560 |
On the other hand if I change the code to write a single point at the time:
points = list()
for i in range(10):
for p in points:
print(f"{datetime.now()} writting point...")
client.write(p)
I can see that all points are being created - but with rather a huge delay, taking about 8 seconds to write 10 points individually:
| 0 | Kitchen | 21.5 | 2025-06-15T14:40:00.010867295 |
| 1 | Kitchen | 21.5 | 2025-06-15T14:40:00.851427535 |
| 2 | Kitchen | 21.5 | 2025-06-15T14:40:01.850041324 |
| 3 | Kitchen | 21.5 | 2025-06-15T14:40:02.849303571 |
| 4 | Kitchen | 21.5 | 2025-06-15T14:40:03.849634706 |
| 5 | Kitchen | 21.5 | 2025-06-15T14:40:04.850275765 |
| 6 | Kitchen | 21.5 | 2025-06-15T14:40:05.849237392 |
| 7 | Kitchen | 21.5 | 2025-06-15T14:40:06.849934686 |
| 8 | Kitchen | 21.5 | 2025-06-15T14:40:07.850975463 |
| 9 | Kitchen | 21.5 | 2025-06-15T14:40:08.849148669 |
Any ideas what is that I may be doing wrong?
Thank you and best regards.
