Hello.
I am trying to test Influx 3 OSS, but it does not start. I have tried in Oracle Linux, Fedora and Ubuntu, both normal and docker. Testing from a command line (normalñ install) I always get this:
$ influxdb3 serve --node-id=‘node0’ --http-bind=‘0.0.0.0:8181’ --object-store=file --data-dir /home/erobles/.influxdb/data
Illegal instruction (core dumped).
I am getting this from the system logs:
var/log/kern.log:2025-07-01T15:26:56.207910-04:00 eulogio-robles-VirtualBox2 kernel: traps: influxdb3[3024] trap invalid opcode ip:615add9420e6 sp:7ffeff15b2a0 error:0 in influxdb3[5420e6,615add400000+61bd000]
/var/log/kern.log:2025-07-01T15:29:40.479637-04:00 eulogio-robles-VirtualBox2 kernel: traps: influxdb3[3210] trap invalid opcode ip:61827a7420e6 sp:7ffda199b520 error:0 in influxdb3[5420e6,61827a200000+61bd000]
I have been using Influx 2 for years, without any problem.
Thanks in advance.
I don’t have those OS to try on right now, but just one minor thing, make sure to use ’ - straight quotes as I copy pasted your command and it didn’t work due to incorrect quotes. Everything else looks fine otherwise but let me check more and come back.
I reviewed the command, I do not get any syntax error. Even without quotes, a simple “help” command fails:
$ influxdb3 serve --help
Had same issue, it is due old Processor
influxdb3 --version
While debugging found that it is failing due processor:
0x0000555558ea8808 +2088: mulx %rax,%rbx,%rbx
As I have quite old processor (Sandy Bridge family 2011) and mulx is supported from (broadwell family 2013)
Check which processor u have
I have it in a Ubuntu machine virtualized using VirtualBox (Windows 11 host). The VM sees this in /proc/cpuinfo:
model name : 11th Gen Intel(R) Core™ i5-1135G7 @ 2.40GHz
The physical machine is a HP Pavilion, 2 yr old laptop. I don’t think it should be a problem…
It’s really strange in that case, suggest filing an issue so engineering team can look at it: GitHub · Where software is built
i have the same issue on Xeon CPU
emq@emqxsrv:~/.influxdb$ influxdb3 --version
I am experiencing the same issue on Debian 12 on Proxmox.
In my case, with more /proc/cpuinfo I get:
processor: 0
vendor_id: GenuineIntel
cpu family: 15
model: 107
model name: QEMU Virtual CPU version 2.5+
stepping: 1
microcode: 0x1
The physical CPU is an Intel(R) Core™ i3-6100T on which I run Proxmox. I know it’s quite old, but until now I haven’t had any problems with any software running on Proxmox and Debian.
Does all this mean that Influxdb 3 cannot run on relatively old hardware? What are the minimum requirements for Intel processors?
