Hello all
I am trying to add a plugin but the button that is displayed in the examples is missing on my install?
Heres what the docs say with a “use plugin” button:
Heres mine:
How do I get the button to appear?
Hello @prgrobots,
What version of InfluxDB are you using?
I do:
Left nav bar > second icon (arrow) > Telegraf > blue “+ Create Configuration button” on the right hand side > select plugin.
