InfluxDB v3 Java client fails to initialize inside Apache Flink with gRPC/Arrow Flight URI errors
I am trying to use the InfluxDB v3 Java client inside an Apache Flink streaming job (custom RichSinkFunction).
A simple standalone Java test works correctly (client initialization + writePoint succeeds), but the same client initialization fails when executed inside a Flink task.
Observed Behavior
Inside Flink, the client fails during initialization in open():
java.lang.IllegalArgumentException: java.net.URISyntaxException: Expected scheme-specific part at index 9: grpc+tcp:
    at org.apache.arrow.flight.Location.forGrpcInsecure(Location.java:122)
    at com.influxdb.v3.client.internal.FlightSqlClient.createLocation(FlightSqlClient.java:207)
    at com.influxdb.v3.client.internal.FlightSqlClient.createFlightClient(FlightSqlClient.java:148)
    at com.influxdb.v3.client.internal.FlightSqlClient.<init>(FlightSqlClient.java:102)
    at com.influxdb.v3.client.internal.InfluxDBClientImpl.<init>(InfluxDBClientImpl.java:116)
    at com.influxdb.v3.client.InfluxDBClient.getInstance(InfluxDBClient.java:519)
If I pass the host without scheme:
host:8181
I get the error above.
If I pass the host with scheme:
https://host:8181
I get a different error:
java.lang.IllegalArgumentException: Address types of NameResolver 'unix' not supported by transport
Expected Behavior
The InfluxDB v3 Java client should initialize correctly inside a Flink operator (RichSinkFunction.open()), just like it does in a standalone Java application.
Minimal Reproduction
public class InfluxSink extends RichSinkFunction<SensorEvent> {
    private transient InfluxDBClient client;
    @Override
    public void open(Configuration parameters) throws Exception {
        ClientConfig config = new ClientConfig.Builder()
                .host("https://host:8181")
                .token("TOKEN".toCharArray())
                .database("DB")
                .build();
        this.client = InfluxDBClient.getInstance(config);
    @Override
    public void invoke(SensorEvent value, Context context) {
        // no-op
Executed within a Flink job:
filteredStream.addSink(new InfluxSink());
Environment
  • Apache Flink: (e.g. 1.18.1)
  • Java: 17 (also tested with newer versions)
  • InfluxDB v3 Java client: 1.80 (mvn)
  • OS: macOS / Linux (tested on both)
  • Deployment: local + VM
Additional Notes
  • The same configuration works outside Flink in a plain main() method.
  • The error originates from Arrow Flight (org.apache.arrow.flight.Location).
  • This may be related to classloader isolation, URI parsing, or gRPC/Flight initialization inside Flink runtime.
Questions
  1. Is the InfluxDB v3 Java client officially supported inside Flink jobs?
  2. What is the correct format for .host() when used with Flight/gRPC?
  3. Are there known issues with Arrow Flight + Flink classloader?
  4. Is additional configuration required for gRPC name resolution in this context?
Workarounds I tried
  • Using host with and without scheme
  • Removing any custom NameResolverRegistry configuration
  • Running with parallelism = 1
  • Testing outside Flink (works)
Any guidance would be greatly appreciated.
At a first glance, this looks like a pretty thorny issue, and it’s unclear at a first glance what part of the stack is the source of the problem. It’s very plausible that this is a limitation/issue with how Flink and/or Flight are behaving rather than a bug with the InfluxDB client.
You could try opening an issue in the GitHub repo for the InfluxDB Java client, as that’ll potentially get it in front of a developer who’d be able to dig a little deeper.
Hi @tomorrow, thanks for reaching out.
Our intention in GitHub - InfluxCommunity/influxdb3-java: The Java Client that provides a simple and convenient way to interact with InfluxDB 3. · GitHub was always to require the schema to be specified, because it is crucial for the underlying gRPC initialization. So your configuration, https://host:8181, is correct.
To find the solution, we need to focus on this error:
java.lang.IllegalArgumentException: Address types of NameResolver 'unix' not supported by transport.
This looks like an issue with the NameResolver configuration in your Apache Flink setup.
