What I would like to get is information about each visit duration:
10:00:00; locationA; 5min
10:05:00; locationB; 1 min
10:06:00; locationC; null
Is that possible in InfluxDB cloud SQL? I saw some solutions in previous versions of Influx using functions like elapsed, lag, lead etc. But none of that is available here.
You can do this in SQL as well, I just tried it on my dataset, reference this code and feel free to change it for your measurement assuming it’s called “locations”, values and time duration etc:
WITH ranked_data AS (
SELECT
time AS start_time,
LEAD(time) OVER (ORDER BY time) AS end_time,
location
FROM
"locations"
WHERE
time >= now() - INTERVAL '1 day'
durations AS (
SELECT
start_time,
end_time,
location,
EXTRACT(EPOCH FROM end_time) - EXTRACT(EPOCH FROM start_time) AS duration_seconds
FROM
ranked_data
SELECT
start_time,
location,
CASE
WHEN end_time IS NOT NULL THEN
CONCAT(
CAST(FLOOR(duration_seconds / 60) AS STRING), ' min'
ELSE
'null'
END AS duration
FROM
durations
ORDER BY
start_time;
Basically, you want to do the following 3 things:
Identify the start and end times for each location entry.
Calculate the duration between consecutive entries.
Format the duration in a readable format (e.g., minutes).
Thank you for the answer. I tried a similar solution before using Data Explorer UI, but getting an error like this:
Error while planning query: Error during planning: Invalid function ‘lead’.
Did you mean ‘lpad’?: rpc error: code = InvalidArgument desc = Error while planning query: Error during planning: Invalid function ‘lead’.
Is it possible that Data Explorer UI does not allow it but a different client does?
