How to get how much time elapsed since data point is stored in influxdb
I’m trying to find the time difference between current timestamp and the time a point is entered in influxdb
For example, below query gives me an entry from activealerts measurement.
select env, level, alert_name from activealerts order by time desc limit 1
time env level alert_name
1596542152514023232 uat CRITICAL alerts_cron_jobs
Here I would like to know, how much time have elapsed since this entry was made.
I tried as below
select now() - time, env, level, alert_name from activealerts order by time desc limit 1
ERR: undefined function now()
This seems very simple thing to do, but I dont know how to do it.
Regards,
Robert
Hello @Robert_George,
I don’t think this is something you can do in InfluxQL, however you can do it with Flux in InfluxDB 1.8+.
You can use the the now() function
as well as the first() function to return the most recent point.
as well as the map() function
to write something like this:
from(bucket: "animals")
  |> filter(fn: (r) => r["_measurement"] == "cats")
  |> filter(fn: (r) => r["_field"] == "adult")
  |> filter(fn: (r) => r["shelter"] == "A")
  |> filter(fn: (r) => r["type"] == "calico")
  |> group()
  |> first()
  |> map(fn: (r) => ({ time: uint(v: now()) - uint(v: r._time)}))
Please let me know how you get along!
You can also use the findRecord() findRecord() function | Flux 0.x Documentation function in conjunction with duration() function Manipulate timestamps with Flux | InfluxDB OSS 2.0 Documentation
To do someting like:
time1 = uint(v: 2019-09-17T21:12:05Z)
time2 = uint(v: 2019-09-18T22:16:35Z)
duration(v: time2 - time1)
