Bonjour
Quick question of the day:
I’m under influDB V2.6 and I’m trying to delete data from my buckets (and yes there too I’m out of space)
influxd delete --bucket jeedom --predicate '_measurement="EAIT"' --start 1970-01-01T00:00:00Z --stop 2023-02-16T00:00:00Z
and i have this back
Error: unknown flag: --bucket
See 'influxd -h' for help
of course that I type the command I do not see the options that I found in the doc of influxDB.
Have you ever had this case?
How did you deal with it?
Pooh
February 20, 2023, 4:34pm
2
Use the command influx instead of influxd
Antony.
Thanks for your reply @Pooh
I did this but didn’t get much results!
-bash: influx : commande introuvable
Maybe I need to be in a particular directory to run it?
Pooh:
Which operating system & version is this running on?
InfluxDB and Grafana running on a Debian GNU/Linux 11 Virtual Machine (bullseye)
under proxmox
Pooh:
How was InfluxDB installed?
For how it was installed, I wouldn’t go into detail because I did it a very long time ago.
In 1st I was in version 1.8 then mogration under version 2.0 and about 1 week ago version 2.6
From memory it’s the commands to install v1.8
sudo apt-get update && sudo apt-get install influxdb and wget
Pooh:
Which user are you running the command “influx” as?
I run the command under root user
Pooh:
What is the output of “echo $PATH”?
/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
Pooh
February 21, 2023, 9:17am
6
Okay, so what are the outputs of the two commands:
a) which influx
b) find / -type f -name influx
Antony.
Pooh:
a) which influx
For this I have
/usr/bin/influx
and for that I have
/usr/bin/influx
/usr/share/bash-completion/completions/influx
Thank you very much for your help while waiting to arrive at the final solution
Hello
A little up to help me on the subject!
