Hi, we are using InfluxDB with LibreNMS to provide metrics to Grafana. It was setup based on the following procedure. InfluxDB - LibreNMS Docs
Now after using it for some time there are old .tsm files that are taking a lot of space and the local disk on the device is almost full. Old files are located in the /opt/influxdb/data/librenms/autogen/ folder . From what i understand the default retention policy is forever, need to know how to modify the default policy and is it safe to remove old .tsm files with the rm command.
