Hello everyone, I am on internship in a company, and I installed TIG using docker on a VM.
I don’t stay long in the company and I make them a developer guide and I wanted to know if there was a command (ubuntu) that would update influxdb or grafana for example if necessary.
Just use the same commands you would use for updating anything on an Ubuntu
system - apt, aptitude, synaptic etc.
https://help.ubuntu.com/community/SynapticHowto
Antony.
Hi @Mayelle26,
If you are running InfluxDB locally then @Pooh answer will work perfectly. If you have deployed via containers with something like docker-compose then I highly recommend checking out Watchtower: Docker
this should help look out for image updates and gracefully update them
Ok, thanks, I deployed InfluxDB on Cloud with docker-compose I will see your page. Thank you for your reply.
