i’m new with Influx DB.
I was trying to get the json data trought the REST API with Talend.
It’s the url correct or i need other parameters?
Hello @VictorVelasquezBI,
Welcome!
I see you’re new to InfluxDB. May I ask why are you using InfluxDB 1.x instead of 2.x?
Here’s documentation on using the 1.x query endpoint:
You don’t need the username or password.
