Query flux to influxdb v2 from Google Apps Script
I am having difficulty forwarding flux queries to influxdb v2 from Google Apps Script. Are there any examples I can draw from for these queries?
I tried to transpose an example that works on LUA, but I always get the 400 error.
function queryInfluxDB() {
// Imposta l’URL dell’endpoint Flux di InfluxDB
var url = “https://XXXXXXX/api/v2/query?org=org01”;
// Crea una richiesta POST con il corpo JSON contenente la query Flux
var request = {
“method”: “POST”,
“muteHttpExceptions” : true,
“headers”: {
“Authorization”: “Token XXXXXXXXXXXX”,
// “Accept”: “application/csv”,
“Accept”: “application/json”,
// “Content-Type”: “application/json”
“Content-Type”: “application/vnd.flux”
"payload": JSON.stringify({
  "data": {
    "query": "from(bucket: 'org01casa01') | range(start: -1h, stop: 2h)"
// Invia la richiesta a InfluxDB e ottieni la risposta
Logger.log("url " + url);
for(i in request) {
Logger.log(i + ": " + request[i]);
if (i == “headers”) {
for(j in request[i]) {
Logger.log(j + ": " + request[i][j]);
// for(k in request[i][j]) {
// Logger.log(k + ": " + request[i][j][k]);
var response = UrlFetchApp.fetch(url, request);
Logger.log("response : " + response);
for(i in response) {
Logger.log(i + ": " + response[i]);
Logger.log("response.getResponseCode() : " + response.getResponseCode());
if (response.getResponseCode() === 200) {
// Converte la risposta JSON in un oggetto JavaScript
var responseData = JSON.parse(response.getContentText());
Logger.log(" duecento " + response.getResponseCode() + " " + responseData);
for(i in responseData) {
 Logger.log(i + ": " + responseData[i]);
 for(j in responseData[i]) {
  Logger.log(j + ": " + responseData[i][j]);
  for(k in responseData[i][j]) {
   Logger.log(k + ": " + responseData[i][j][k]);
else {
console.error(“Errore durante l’esecuzione della query Flux:”, response.getResponseCode());
@lorenzo.grigoletto I see an error in your Flux query. You’re currently using a pipe (|) between functions, but Flux uses what’s called a pipe-forward (|>):
  "data": {
-    "query": "from(bucket: 'org01casa01') | range(start: -1h, stop: 2h)"
+    "query": "from(bucket: 'org01casa01') |> range(start: -1h, stop: 2h)"
Do you get any errors back when you try to run this?
Thanks for the suggestion, I had forgotten to revert the modification made back to the original version.
I keep getting the error 400.
I am including some lines from the debug if they may be helpful:
Accept: application/json
Content-Type: application/vnd.flux
payload: {data:{query:from(bucket: ‘org01casa01’) |> range(start: -1h, stop: 2h)}}
response : {code:invalid,message:error in query specification while starting program: this Flux script returns no streaming data. Consider adding a \yield\ or invoking streaming functions directly, without performing an assignment}
Hello @lorenzo.grigoletto,
have you tried adding a |>yield() as the error suggests? In your query?
Is it possible you don’t have data available in that time range? Can you please check by increasing the time range as well?
Thanks for the suggestion, but I have already tried inserting |> yield() and the data is there (a lot of it, too) as you can see from the screenshot.
I attach some information from the log:
payload: {“data”:{“query”:"from(bucket: ‘org01casa01’) |> range(start: -1d, stop: 2h) |>yield() "}}
response : {“code”:“invalid”,“message”:“error in query specification while starting program: this Flux script returns no streaming data. Consider adding a "yield" or invoking streaming functions directly, without performing an assignment”}
I make many of these calls from a Fibaro HC3/Yubii machine where there is a LUA environment, and I have no problem.
I also have many iterations from Node Red without any difficulty.
Where can I find examples of calls from Google Apps Script?
That’s very odd. Your query looks to be identical. Are you able to query any other databases? And v2 uses a unified API so it doesn’t make sense that you’re able to query within the UI with that query and not make the cuRL request.
Can you try:
curl --request POST \
  http://localhost:8086/api/v2/query?orgID=INFLUX_ORG_ID  \
  --header 'Authorization: Token INFLUX_TOKEN' \
  --header 'Accept: application/csv' \
  --header 'Content-type: application/vnd.flux' \
  --data "from(bucket: ‘org01casa01’) |> range(start: -1d, stop: 2h)'
please?
Good morning,
I tried this curl call from both windows 10 and Node Red and it works (I limited the range to reduce the number of occurrences extracted).
curl --request POST “https://XXXXXXX/api/v2/query?org=org01” --ssl-no-revoke --header “Authorization: XXXXXXXXXXXXX” --header “Accept: application/csv” --header “Content-type:application/vnd.flux” --data “from(bucket: "org01casa01") |> range(start: -10m, stop: 2m)”
Attached is the result of the call.
,result,table,_start,_stop,_time,_value,_field,_measurement
,_result,0,2024-04-17T07:32:45.400047091Z,2024-04-17T07:44:45.400047091Z,2024-04-17T07:35:01Z,4.5,Temperature,MeteoEsterno
,_result,0,2024-04-17T07:32:45.400047091Z,2024-04-17T07:44:45.400047091Z,2024-04-17T07:40:01Z,4.5,Temperature,MeteoEsterno
,result,table,_start,_stop,_time,_value,_field,_measurement,deviceID,deviceName
,_result,1,2024-04-17T07:32:45.400047091Z,2024-04-17T07:44:45.400047091Z,2024-04-17T07:41:04Z,true,valuenew,OpeningSensorvalue,32,PFFinestraCameraJuve
,_result,1,2024-04-17T07:32:45.400047091Z,2024-04-17T07:44:45.400047091Z,2024-04-17T07:42:17Z,false,valuenew,OpeningSensorvalue,32,PFFinestraCameraJuve
,_result,2,2024-04-17T07:32:45.400047091Z,2024-04-17T07:44:45.400047091Z,2024-04-17T07:41:04Z,false,valueold,OpeningSensorvalue,32,PFFinestraCameraJuve
,_result,2,2024-04-17T07:32:45.400047091Z,2024-04-17T07:44:45.400047091Z,2024-04-17T07:42:17Z,true,valueold,OpeningSensorvalue,32,PFFinestraCameraJuve
,_result,3,2024-04-17T07:32:45.400047091Z,2024-04-17T07:44:45.400047091Z,2024-04-17T07:33:20Z,45.2,valuenew,PowerMetervalue,83,Potenza
,_result,3,2024-04-17T07:32:45.400047091Z,2024-04-17T07:44:45.400047091Z,2024-04-17T07:36:55Z,45.1,valuenew,PowerMetervalue,83,Potenza
,_result,3,2024-04-17T07:32:45.400047091Z,2024-04-17T07:44:45.400047091Z,2024-04-17T07:41:55Z,44.5,valuenew,PowerMetervalue,83,Potenza
,_result,4,2024-04-17T07:32:45.400047091Z,2024-04-17T07:44:45.400047091Z,2024-04-17T07:33:20Z,44.8,valueold,PowerMetervalue,83,Potenza
,_result,4,2024-04-17T07:32:45.400047091Z,2024-04-17T07:44:45.400047091Z,2024-04-17T07:36:55Z,45.2,valueold,PowerMetervalue,83,Potenza
,_result,4,2024-04-17T07:32:45.400047091Z,2024-04-17T07:44:45.400047091Z,2024-04-17T07:41:55Z,45.1,valueold,PowerMetervalue,83,Potenza
,_result,5,2024-04-17T07:32:45.400047091Z,2024-04-17T07:44:45.400047091Z,2024-04-17T07:35:04Z,uibutton1OnReleased,event1.data.actionName,QuickApp,132,InterfacciaInfluxdb
,_result,5,2024-04-17T07:32:45.400047091Z,2024-04-17T07:44:45.400047091Z,2024-04-17T07:36:42Z,uibutton3OnReleased,event1.data.actionName,QuickApp,132,InterfacciaInfluxdb
,_result,5,2024-04-17T07:32:45.400047091Z,2024-04-17T07:44:45.400047091Z,2024-04-17T07:39:17Z,uibutton3OnReleased,event1.data.actionName,QuickApp,132,InterfacciaInfluxdb
,_result,5,2024-04-17T07:32:45.400047091Z,2024-04-17T07:44:45.400047091Z,2024-04-17T07:40:03Z,uibutton1OnReleased,event1.data.actionName,QuickApp,132,InterfacciaInfluxdb
,_result,5,2024-04-17T07:32:45.400047091Z,2024-04-17T07:44:45.400047091Z,2024-04-17T07:41:54Z,uibutton3OnReleased,event1.data.actionName,QuickApp,132,InterfacciaInfluxdb
,_result,5,2024-04-17T07:32:45.400047091Z,2024-04-17T07:44:45.400047091Z,2024-04-17T07:41:59Z,uibutton3OnReleased,event1.data.actionName,QuickApp,132,InterfacciaInfluxdb
,_result,6,2024-04-17T07:32:45.400047091Z,2024-04-17T07:44:45.400047091Z,2024-04-17T07:35:41Z,SceneModifiedEvent,event1.type,Scene,100,QueryInfluxdbDATI
,_result,6,2024-04-17T07:32:45.400047091Z,2024-04-17T07:44:45.400047091Z,2024-04-17T07:36:41Z,SceneModifiedEvent,event1.type,Scene,100,QueryInfluxdbDATI
,_result,6,2024-04-17T07:32:45.400047091Z,2024-04-17T07:44:45.400047091Z,2024-04-17T07:36:42Z,SceneStartedEvent,event1.type,Scene,100,QueryInfluxdbDATI
,_result,6,2024-04-17T07:32:45.400047091Z,2024-04-17T07:44:45.400047091Z,2024-04-17T07:39:17Z,SceneModifiedEvent,event1.type,Scene,100,QueryInfluxdbDATI
,_result,6,2024-04-17T07:32:45.400047091Z,2024-04-17T07:44:45.400047091Z,2024-04-17T07:41:54Z,SceneModifiedEvent,event1.type,Scene,100,QueryInfluxdbDATI
,_result,7,2024-04-17T07:32:45.400047091Z,2024-04-17T07:44:45.400047091Z,2024-04-17T07:35:00Z,SceneStartedEvent,event1.type,Scene,79,EstrazioneHC3UTC
,_result,7,2024-04-17T07:32:45.400047091Z,2024-04-17T07:44:45.400047091Z,2024-04-17T07:40:00Z,SceneStartedEvent,event1.type,Scene,79,EstrazioneHC3UTC
,_result,8,2024-04-17T07:32:45.400047091Z,2024-04-17T07:44:45.400047091Z,2024-04-17T07:44:22Z,24.8,valuenew,TemperatureSensorvalue,55,MovSalotto
,_result,9,2024-04-17T07:32:45.400047091Z,2024-04-17T07:44:45.400047091Z,2024-04-17T07:44:22Z,25,valueold,TemperatureSensorvalue,55,MovSalotto
C:\Users\User>
Morning,
I don’t know why, but the copy/past deletes the \ before the ".
So within the query you have to insert the \ before the " .
