Hi all,
I tried using replication to back up my local InfluxDB to Influx Cloud in real-time, but I noticed the upload speed is very slow (around 800 bytes/10 seconds). According to the report from influx replication list, the latest status code is consistently 204, which indicates no issues. I’ve checked both CPU and network usage, and they are low, so it’s not a limitation of the device or network speed.
I also tried using Influx’s task function to perform backups every 10 minutes, and while the task runs successfully, we prefer real-time data, so I would rather use replication.
Could you help identify the issue and suggest how to resolve it?
Thank you so much ![]()
