With my njmon we can collect loads of data on this HW and OS combinations and 700 stats from AIX & VIOS but most POWER guys don’t want to run InfluxDB of nasty little Intel boxes
I recompiled and got the basic influxd and influx CLI binaries but it gets hard to build the install packages.
Any chance of an official POWER processor release?
Cheers, Nigel Griffiths
ps: My S922LC has 160 CPUs and 256 GB RAM - it should run Influxdb very nicely!
pps: I also run Influxdb on two Raspberry Pi 3B and it runs well - which demo’s high efficiency - I was impressed.
ppps: Perhaps, hope to see you at Influxdays in London in June
I regularly recompile for various architectures – arm64 mostly, but sometimes MIPS – so it’s pretty straightforward. As for building actual install packages once built, You can probably pull some scripts for building install packages for your architecture from somewhere and just add those to the Makefile
to auto-build.
Hope to see you in London!
dg
Just a quick thought:
https://www.power-devops.com/influxdb are compiling InfluxDB for Linux on POWER and now for AIX on POWER.
I humbly suggest you add this to your support platforms lists.
For AIX users I have njmon for collect 600+ stats from AIX and pump them in the InfluxDB via JSON and the InfluxDB client for Python.
There is a million AIX operating systems running out there that you are missing.
The InfluxDB Download page assumes Intel is running the planet with binaries for
AMD64, AMD64,AMD64,AMD64,AMD64,AMD64,AMD64,AMD64,AMD64,and ARM.
I’d suggest filing an issue in Github about this. That way it will get surfaced to engineering.
dg
Thanks for the advice but you assume rather a lot.
I eventually found how to “file an issue in Github”. . . I think!
Cheer, N
