I’m trying to query a postgres db as described in the docs.
import "sql"
sql.from(
driverName: "postgres",
dataSourceName: "postgresql://my-usr:my-psw@postgres",
query: "SELECT * FROM metadata"
where metadata is a table I created in postgres.
I also tried specifying the db as dataSourceName: "postgresql://my-usr:my-psw@postgres/my-db", but no luck.
I tried to run the query both using the UI and influx query but I always get the generic error:
Error: An internal error has occurred.
In my case, the two services are inside the same network, I’m able to ping postgres if I log into influxdb. My docker-compose looks like this:
version: "3.5"
services:
influxdb:
image: influxdb:2.0.4
container_name: influxdb
ports:
- 8086:8086
environment:
- DOCKER_INFLUXDB_INIT_MODE=setup
- DOCKER_INFLUXDB_INIT_USERNAME=my-usr
- DOCKER_INFLUXDB_INIT_PASSWORD=my-psw
- DOCKER_INFLUXDB_INIT_ORG=my-org
- DOCKER_INFLUXDB_INIT_BUCKET=my-bucket
- DOCKER_INFLUXDB_INIT_RETENTION=53w
- DOCKER_INFLUXDB_INIT_ADMIN_TOKEN=my-auth-token
postgres:
build: postgres
container_name: postgres
environment:
- POSTGRES_DB=my-db
- POSTGRES_USER=my-usr
- POSTGRES_PASSWORD=my-psw
How can I find additional info about the error and fix it? The generic error message is not giving me any clue.
