I am sending data to influx via telegraf. Suddenly, my influxdb has stopped.
These are the error logs of the telegraf from the time when Influxdb stopped.
2017-04-13T09:23:00Z E! Error writing to output [file]: failed to write message: kernel,host=DHARI-Inspiron-3542 processes_forked=196837i,interrupts=150752942i,context_switches=265819737i,boot_time=1491987066i 1492075370000000000 , invalid argument
2017-04-13T09:23:00Z E! InfluxDB Output Error: {"error":"engine: cache-max-memory-size exceeded: (1073763734/1073741824)"}
2017-04-13T09:23:00Z E! Error writing to output [influxdb]: Could not write to any InfluxDB server in cluster
Then, when I tried to restart the influxdb service,
It did not start, and telegraf’s error logs showed this,
2017-04-13T13:23:00Z E! Error writing to output [file]: failed to write message: pg_stat_all_tables,host=DHARI-Inspiron-3542,server=db01,db=postgres seq_tup_read=0i,n_tup_ins=0i,n_dead_tup=0i,autovacuum_count=0i,n_tup_hot_upd=0i,n_tup_upd=0i,relname="sql_features",n_tup_del=0i,relid="12242",schemaname="information_schema",analyze_count=0i,n_live_tup=0i,seq_scan=0i,n_mod_since_analyze=0i,vacuum_count=0i,autoanalyze_count=0i 1492089100000000000 , invalid argument
2017-04-13T13:23:00Z E! InfluxDB Output Error: Post http://127.0.0.1:8086/write?consistency=any&db=telegraf&precision=ns&rp=: dial tcp 127.0.0.1:8086: getsockopt: connection refused
2017-04-13T13:23:00Z E! Error writing to output [influxdb]: Could not write to any InfluxDB server in cluster
When I try to launch the influx command line, I get
luvpreet@DHARI-Inspiron-3542:/etc/influxdb$ influx
Failed to connect to http://localhost:8086: Get http://localhost:8086/ping: dial tcp 127.0.0.1:8086: getsockopt: connection refused
Please check your connection settings and ensure 'influxd' is running.
But the status shows that it is running !!! Here have a look,
luvpreet@DHARI-Inspiron-3542:/etc/influxdb$ sudo service influxdb status
● influxdb.service - InfluxDB is an open-source, distributed, time series database
Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2017-04-13 19:05:20 IST; 43ms ago
Docs: https://docs.influxdata.com/influxdb/
Main PID: 32211 (influxd)
Tasks: 6
Memory: 3.4M
CPU: 8ms
CGroup: /system.slice/influxdb.service
└─32211 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
Apr 13 19:05:20 DHARI-Inspiron-3542 influxd[32211]: [I] 2017-04-13T13:35:20Z InfluxDB starting, version 1.2.2, branch master, commit 1bcf3ae74c
Apr 13 19:05:20 DHARI-Inspiron-3542 influxd[32211]: [I] 2017-04-13T13:35:20Z Go version go1.7.4, GOMAXPROCS set to 4
Apr 13 19:05:20 DHARI-Inspiron-3542 influxd[32211]: [I] 2017-04-13T13:35:20Z Using configuration at: /etc/influxdb/influxdb.conf
After reading the telegraf logs, I thought it might be occuring as my cache is full, so I doubled my
cache-max-memory-size = 2048576000
But it still does not start.
The biggest thing is that the log file has been automatically deleted and I cannot have a clue about what happened as long as there will be no logs.
Also, I want to discuss that increasing the cache size will take more RAM, and can hinder system performance.
And also, how does influx assure data-persistence of the data in the cache ?
