Hi everyone. I am using a kafka broker as an input plugin…i wanted to monitor the kafka broker, if data doesnot comes in past 15m i want to setup an alert. For monitoring i found this template - Kafka Monitoring Dashboard Template | InfluxData. I am facing issue in understanding the usage of template and how to use it. The telegraf config for this template is this -
[[inputs.jolokia2_agent]]
default_tag_prefix = ""
default_field_prefix = ""
default_field_separator = "_"
urls = ["$KAFKA_JOLOKIA_HOSTS"]
# (still have to add Type=DelayedOperationPurgatory)
[[inputs.jolokia2_agent.metric]]
name = "kafka_replica_manager"
mbean = "kafka.server:type=ReplicaManager,name=*"
paths = ["Count"]
field_name = "$1"
mbean = "kafka.server:type=ReplicaManager,name=PartitionCount"
field_name = "PartitionCount"
mbean = "kafka.server:type=ReplicaManager,name=LeaderCount"
field_name = "LeaderCount"
mbean = "kafka.server:type=ReplicaManager,name=UnderReplicatedPartitions"
field_name = "UnderReplicatedPartitions"
name = "kafka_broker"
mbean = "kafka.server:type=kafka-metrics-count"
field_name = "kafka_metrics_count"
mbean = "kafka.server:type=BrokerTopicMetrics,name=*"
mbean = "kafka.server:type=DelayedOperationPurgatory,name=NumDelayedOperations,delayedOperation=*"
field_name = "$1"
mbean = "kafka.server:type=Produce"
field_name = "ProduceQueueSize"
name = "kafka_topics"
mbean = "kafka.server:type=BrokerTopicMetrics,name=*,topic=*"
paths = ["Count"]
field_name = "$1"
tag_keys = ["topic"]
name = "kafka_purgatory"
mbean = "kafka.server:name=PurgatorySize,type=DelayedOperationPurgatory,delayedOperation=*"
tag_keys = ["delayedOperation"]
name = "kafka_controller"
mbean = "kafka.controller:type=KafkaController,name=*"
field_name = "$1"
mbean = "kafka.controller:type=ControllerStats,name=LeaderElectionRateAndTimeMs"
paths = ["Count"]
tag_keys = ["name"]
mbean = "kafka.controller:type=ControllerStats,name=UncleanLeaderElectionsPerSec"
paths = ["Count"]
tag_keys = ["name"]
name = "kafka_network"
mbean = "kafka.network:type=RequestMetrics,name=ErrorsPerSec,request=*,error=*"
paths = ["Count"]
tag_keys = ["name", "request"]
field_name = "$2"
mbean = "kafka.network:type=RequestMetrics,name=TotalTimeMs,request=*"
paths = ["Count"]
# from kafka.network
name = "kafka_requests"
mbean = "kafka.network:type=RequestMetrics,name=RequestBytes,request=*"
tag_keys = ["request"]
field_prefix = "Bytes"
mbean = "kafka.network:type=RequestMetrics,name=RequestQueueTimeMs,request=*"
field_prefix = "QueueTime"
mbean = "kafka.network:type=RequestMetrics,name=RequestsPerSec,request=*,version=*"
paths = ["Count"]
field_name = "Count"
name = "kafka_partition"
mbean = "kafka.log:name=*,partition=*,topic=*,type=Log"
field_name = "$1"
tag_keys = ["topic", "partition"]
mbean = "kafka.cluster:name=UnderReplicated,partition=*,topic=*,type=Partition"
# JVM
name = "jvm_runtime"
mbean = "java.lang:type=Runtime"
paths = ["Uptime", "StartTime", "VmName", "SpecVersion"]
name = "jvm_os"
mbean = "java.lang:type=OperatingSystem"
paths = ["AvailableProcessors", "SystemLoadAverage", "FreePhysicalMemorySize", "TotalPhysicalMemorySize", "CommittedVirtualMemorySize", "Name", "Version", "ProcessCpuLoad", "SystemCpuLoad"]
name = "jvm_mem"
mbean = "java.lang:type=Memory"
paths = ["HeapMemoryUsage", "NonHeapMemoryUsage"]
name = "jvm_threading"
mbean = "java.lang:type=Threading"
paths = ["TotalStartedThreadCount", "PeakThreadCount", "ThreadCount", "DaemonThreadCount"]
name = "java_gc"
mbean = "java.lang:name=*,type=GarbageCollector"
paths = ["CollectionTime", "CollectionCount"]
tag_keys = ["name"]
name = "java_classes"
mbean = "java.lang:type=ClassLoading"
paths = ["LoadedClassCount", "UnloadedClassCount", "TotalLoadedClassCount"]
name = "java_mem_pool"
mbean = "java.lang:name=*,type=MemoryPool"
paths = ["Usage"]
tag_keys = ["name"]
# KAFKA PRODUCERS
urls = ["$KAFKA_PRODUCERS_JOLOKIA_HOSTS"]
name = "kafka_producer"
mbean = "kafka.producer:type=producer-metrics,client-id=*"
paths = ["compression-rate-avg", "response-rate", "request-rate", "request-latency-avg", "outgoing-byte-rate", "io-wait-ratio", "batch-size-avg"]
tag_keys = ["client-id"]
# JVM
name = "jvm_os"
name = "jvm_mem"
name = "java_gc"
tag_keys = ["name"]
paths = ["Usage"]
tag_keys = ["name"]
# KAFKA CONSUMERS
urls = ["$KAFKA_CONSUMERS_JOLOKIA_HOSTS"]
name = "kafka_consumer"
mbean = "kafka.consumer:type=consumer-fetch-manager-metrics,client-id=*,topic=*"
paths = ["bytes-consumed-rate", "records-consumed-rate"]
tag_keys = ["client-id", "topic"]
mbean = "kafka.consumer:type=consumer-fetch-manager-metrics,client-id=*,partition=*,topic=*"
paths = ["records-lag-avg"]
tag_keys = ["client-id", "partition", "topic"]
mbean = "kafka.consumer:type=consumer-fetch-manager-metrics,client-id=*"
paths = ["fetch-rate"]
# JVM
name = "jvm_os"
name = "jvm_mem"
name = "java_gc"
tag_keys = ["name"]
paths = ["Usage"]
tag_keys = ["name"]
I am confused which plugin to choose and what value should i put there. I have kafka broker and topic name and i only want to see whether data loss is there recently in past 15 min. Can anybody help me here in dealing with this config.
