Hi all,
How to config and deploy influxdb (telegraf) to monitor Kafka
Thanx
Hi all,
Thanx
Hello @rijaluc,
Welcome!
You’ll need to install telegraf and InfluxDB:
Or sign up for InfluxDB Cloud:
Then you can either configure Telegraf through the UI:
Or configure it mannually:
You’ll want to follow:
Getting started with telegraf
And then use the kafka input plugin
And the InfluxDB v2 output plugin:
You’ll have to configure the Influx v2 output plugin portion of your telegraf config with the following information:
Watch this on how to manually configure it:
Let me know if you have questions after taking a look at that!
Hello @Anaisdg
thanks for your support but I has on problem on Jolokia
Below the step we has done :
After vérification on localhost:8778/jolokia/list the page is unreachable.
Can you help us please ?![]()
Note: I’m using Confluent Kafka
Hello @rijaluc,
Can you include:
debug = true
In the agent portion of your config and share the logs?
Thank you.
Hello @Anaisdg , thanks for your support, the problem of jolokia is resloved.
I have an issue question about telegraf to Influxdb.
1- We install telegraf and Kafka on my windows OS
2- We configure the telegraf.conf. Below
[agent]
interval = “20s”
round_interval = true
metric_batch_size = 4000
metric_buffer_limit = 40000
collection_jitter = “0s”
flush_interval = “10s”
flush_jitter = “0s”
precision = “”
hostname = “”
omit_hostname = false
[[outputs.influxdb]]
urls = [“http://localhost:8086”]
database = “telegraf”
skip_database_creation = true
[[inputs.jolokia2_agent]]
urls = [“http://localhost:8778/jolokia”]
name_prefix = “kafka.”
[[inputs.jolokia2_agent.metric]]
name = “heap_memory_usage”
mbean = “java.lang:type=Memory”
paths = [“HeapMemoryUsage”]
name = “thread_count”
mbean = “java.lang:type=Threading”
paths = [“TotalStartedThreadCount”,“ThreadCount”,“DaemonThreadCount”,“PeakThreadCount”]
name = “garbage_collector”
mbean = “java.lang:type=GarbageCollector,name=*”
paths = [“CollectionCount”,“CollectionTime”]
tag_keys = [“name”]
name = “server_brokertopics_messagesinpersec”
mbean = “kafka.server:type=BrokerTopicMetrics,name=MessagesInPerSec”
name = “server_brokertopics_bytesinpersec”
mbean = “kafka.server:type=BrokerTopicMetrics,name=BytesInPerSec”
name = “server_brokertopics_bytesoutpersec”
mbean = “kafka.server:type=BrokerTopicMetrics,name=BytesOutPerSec”
name = “server_requesthandler_avgidlepct”
mbean = “kafka.server:name=RequestHandlerAvgIdlePercent,type=KafkaRequestHandlerPool”
name = “server_delayedoperationpugatory_fetch”
mbean = “kafka.server:type=DelayedOperationPurgatory,name=PurgatorySize,delayedOperation=Fetch”
name = “server_delayedoperationpugatory_produce”
mbean = “kafka.server:type=DelayedOperationPurgatory,name=PurgatorySize,delayedOperation=Produce”
name = “server_replicafetchmanager.maxlag”
mbean = “kafka.server:type=ReplicaFetcherManager,name=MaxLag,clientId=Replica”
name = “server_replicamanager_underreplicated”
mbean = “kafka.server:type=ReplicaManager,name=UnderReplicatedPartitions”
name = “server_replicamanager_partitioncount”
mbean = “kafka.server:type=ReplicaManager,name=PartitionCount”
name = “server_replicamanager_leadercount”
mbean = “kafka.server:type=ReplicaManager,name=LeaderCount”
name = “server_replicamanager_isrshrinkspersec”
mbean = “kafka.server:type=ReplicaManager,name=IsrShrinksPerSec”
name = “server_replicamanager_isrexpandspersec”
mbean = “kafka.server:type=ReplicaManager,name=IsrExpandsPerSec”
name = “network_requestmetrics_requests_fetch_consumer”
mbean = “kafka.network:type=RequestMetrics,name=RequestsPerSec,request=FetchConsumer”
name = “network_requestmetrics_requests_fetch_follower”
mbean = “kafka.network:type=RequestMetrics,name=RequestsPerSec,request=FetchFollower”
name = “network_requestmetrics_requests_produce”
mbean = “kafka.network:type=RequestMetrics,name=RequestsPerSec,request=Produce”
name = “network_requestmetrics_totaltime_fetch_consumer”
mbean = “kafka.network:type=RequestMetrics,name=TotalTimeMs,request=FetchConsumer”
name = “network_requestmetrics_totaltime_fetch_follower”
mbean = “kafka.network:type=RequestMetrics,name=TotalTimeMs,request=FetchFollower”
name = “network_requestmetrics_totaltime_produce”
mbean = “kafka.network:type=RequestMetrics,name=TotalTimeMs,request=Produce”
name = “network_processor_avgidlepct”
mbean = “kafka.network:name=NetworkProcessorAvgIdlePercent,type=SocketServer”
name = “controller_activecontrollers”
mbean = “kafka.controller:type=KafkaController,name=ActiveControllerCount”
name = “controller_offlinepartitions”
mbean = “kafka.controller:type=KafkaController,name=OfflinePartitionsCount”
name = “controller_stats_leaderelectionrateandtime”
mbean = “kafka.controller:type=ControllerStats,name=LeaderElectionRateAndTimeMs”
name = “controller_stats_uncleanleaderelections”
mbean = “kafka.controller:type=ControllerStats,name=UncleanLeaderElectionsPerSec”
name = “zookeeper_disconnects”
mbean = “kafka.server:type=SessionExpireListener,name=ZooKeeperDisconnectsPerSec”
paths = [“Count”,“OneMinuteRate”,“FiveMinuteRate”,“FifteenMinuteRate”,“MeanRate”]
name = “zookeeper_sync_connects”
mbean = “kafka.server:type=SessionExpireListener,name=ZooKeeperSyncConnectsPerSec”
name = “zookeeper_auth_failures”
mbean = “kafka.server:type=SessionExpireListener,name=ZooKeeperAuthFailuresPerSec”
name = “zookeeper_readonly_connects”
mbean = “kafka.server:type=SessionExpireListener,name=ZooKeeperReadOnlyConnectsPerSec”
name = “zookeeper_authentications”
mbean = “kafka.server:type=SessionExpireListener,name=ZooKeeperSaslAuthenticationsPerSec”
name = “zookeeper_expires”
mbean = “kafka.server:type=SessionExpireListener,name=ZooKeeperExpiresPerSec”
3- We start the telegraf and is UP
So after checking on Influxb (localhost:8086) we don’t see anything .
Hello @rijaluc,
Can you please include:
debug = true
Like:
[agent]
interval = “20s”
flush_jitter = “0s”
precision = “”
hostname = “”
debug = true
Without doing this and sharing the logs I don’t have any information I need to help you. Thank you ![]()
