We have an InfluxDB docker instance running on our redhat host OS.
That instance currently can’t be killed anymore not even with kill -9, so the process must be stuck in a blocking kernel call. (See: process - What if 'kill -9' does not work? - Unix & Linux Stack Exchange)
The block happened at the end of the startup phase. So our last log messages are that a lots of shards were loaded (tsi1 indexed data), but not a single request was logged yet (our metrics should usually write at last every 10 seconds data and writes would be visible in the logs).
As base, we use influxdb:1.7 image.
Any idea on what could have happend? The container is currently still stuck, as the machine is quite important and the reboot is scheduled for somewhere the next week, but I have no idea, if we can debug something in that situation?
Best regards
Theo
