I have recently deployed influxdb using the official docker image. However, I will encounter write timeout whenever, the memory usage reaches 1Gb. The docker container is created with 8GB ram.
Belong is my config,
"Config": { "AttachStderr": false, "AttachStdin": false, "AttachStdout": false, "Cmd": [ "influxd" ], "Domainname": "", "Entrypoint": [ "/entrypoint.sh" ], "Env": [ "INFLUXD_STORAGE_CACHE_MAX_MEMORY_SIZE=4294967296", "PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin", "GOSU_VER=1.12", "INFLUXDB_VERSION=2.1.1", "INFLUX_CLI_VERSION=2.2.1", "INFLUX_CONFIGS_PATH=/etc/influxdb2/influx-configs", "INFLUXD_INIT_PORT=9999", "INFLUXD_INIT_PING_ATTEMPTS=600", "DOCKER_INFLUXDB_INIT_CLI_CONFIG_NAME=default" ], "ExposedPorts": { "8086/tcp": {} }, "Hostname": "9e338154d88e", "Image": "influxdb:latest", "Labels": { "com.docker.swarm.node.id": "vcm3hdheg7m1r6vnod6xdgyum", "com.docker.swarm.service.id": "s5385gxt9pnbb55y595yyj6ur", "com.docker.swarm.service.name": "influx", "com.docker.swarm.task": "", "com.docker.swarm.task.id": "zodo5rzedn0q7w00nfidx1z43", "com.docker.swarm.task.name": "influx.2.zodo5rzedn0q7w00nfidx1z43" }, "OnBuild": null, "OpenStdin": false, "StdinOnce": false, "Tty": false, "User": "", "Volumes": { "/etc/influxdb2": {}, "/var/lib/influxdb2": {} }, "WorkingDir": "" },
