Hi guys,
I’m new in this, and i have two big problems.
I configuration my influxdb in docker but when i need write metrics in my BBDD, influxdb show me the next error:
ts=2021-01-08T21:37:10.019605Z lvl=info msg="failed to store statistics" log_id=0R_zI6OW000 service=monitor error="database not found: _internal"
ts=2021-01-08T21:37:20.028249Z lvl=info msg="Failed to create storage" log_id=0R_zI6OW000 service=monitor db_instance=_internal error="rename /var/lib/influxdb/meta/meta.dbtmp /var/lib/influxdb/meta/meta.db: device or resource busy"
ts=2021-01-08T21:37:20.028613Z lvl=info msg="failed to store statistics" log_id=0R_zI6OW000 service=monitor error="database not found: _internal"
I know, it is very difficult for you to determine what my problem may be but I do not understand what is wrong. My .conf file:
[shard]
store-enabled = true
store-database = "mybbdd"
store-interval = "10s"
my other problem is with the connection between influxdb and telegraf.
`2021-01-08T21:44:25Z E! [agent] Error writing to outputs.influxdb: could not write any address`
`2021-01-08T21:44:35Z E! [outputs.influxdb] When writing to [http://127.0.0.1:8086]: Post "http://127.0.0.1:8086/write?db=mybbdd": dial tcp 127.0.0.1:8086: connect: connection refused`
.conf file:
urls = ["http://127.0.0.1:8086"]
## HTTP Basic Auth
username = "admin"
password = "admin123"
database = "mybbdd"
## HTTP User-Agent
user_agent = "telegraf"
Thank you! Regards, and i appreciate any help.
PS: Sorry for my english xD
